Adjust regen braking for city driving to reduce coasting
Hello friends,
Not sure if anyone has played with Regen braking or it is controlled by car computer and PCB.
If it can be varied for city and highway driving's and reduce coasting in city with more regen we can get better mileage
Has any forum members have played with adjusting the regen braking to reduce coasting and charge more
In B mode, there is no fuel supplied to the engine and ICE is used as air ballast to slow down the vehicle. When B mode - Brake mode - is used fo rbraking. If it's used for driving, it acts just like normal D mode.
No, you can't "adjust" regen braking. Algorithm is - 80% pf braking power supplied by regen and demand above it calls for hydraulics to pitch in. So PLAN YOUR BRAKING.
The following 2 users liked this post by ukrkoz:
Geemaan (07-11-21),
professorm (02-22-22)
Thank you.
There is a huge difference in Tesla Regen braking vs Lexus RX400H.
Comparatively Tesla Regen braking slows the car better and does not coast like RX400H.
The RX400H rolls really free and have a very limited GN coast.
This is what I have played and found.
Stop lights are not synched and in most cases the Stop signs don’t have timers.
So coasting needs constant braking to zero stop and jam the brakes
As you said planning for braking is needed and we can incorporate a little better in known roads.
Speed limits are 45 mph. However what I noticed is if I maintain below 40 mph it runs on battery.
So let me play with it and see how the mileage improves.
The QT 91 with QT gas mileage booster Gave a 28.6 mpg with AC and a cruise speeds of 73. So add 2.86 Ac drop gets me a mileage of 31.5 mpg and guess if I drop down to 65 will see another 5 to 10% pushing it to 33+ which is pretty impressive.
I want to push boundaries to see if I can get 500+ on a tank of gas.
Current Generation ES 300h's have AGC, Automatic Glide Control. This is opposite of what Geemaan is seeking but does
have some merit. As mentioned, Tesla can be "one pedal" driven by pressing the throttle to go and lifting to stop. Works
terrifically but you must consistently modulate your foot to maintain speed and vehicle spacing. Lexus Hybrids have always
had what Tesla labels "Chill" which regenerates somewhat but not as aggressively. Conventional cars have been set up to
coast or glide as far as possible to aid mileage. AGC lets us do both...when you first lift from the throttle the ACG light comes
on to let you know it is coasting with little or no regen. Great when the goal is to glide a fairly long distance and maintain speed.
If the situation calls for an eventual stop then you can tap the brake pedal and you're back to normal Synergy Drive moderate
regen. Maximize regen as always by continuing to apply very light brake pedal pressure (watch the Power Meter to learn how
much is too much) up to the stop. Sport Driving Mode seems to add greater regen than the sudden action created using the
old "B" method.
old "B" method.
In speed performance driving you learn to brake as late as possible and then as heavily as necessary.
In hybrid driving you learn to begin braking as early as needed and as lightly as possible.
I never saw much value in the Tachometer even with a manual car...
if I was driving that hard I was watching the road and not the dashboard.
Lexus/Toyota display the Power Meter (except in Sport Driving Mode) and it really helps
by showing you just how hard to brake to maximize the regen process.
Next time you are driving a Synergy Drive vehicle and are slowing down from 30 - 40 MPH with the brake pedal
very lightly applied to enable the maximum regen try pushing the gear selector out of Drive and into Neutral.
You will immediately feel how much regen was doing because you will begin surging forward without resistance!
Note: Prius and CT200h/HS250h just hold the gear selector to the left for a moment to select Neutral.
Geemaan (07-15-21)
Have you looked into Techstream?
I vaguely remember there were options to adjust the regenerative braking aggressiveness in my sister's 3rd gen Prius.
I wouldn't be surprised if a cheap Mini-VCI cable and some... acquired Techstream software would allow you to customize your RX400h's regen.
Geemaan (07-26-21)
Hello *****,
That was why I raised the question. So far we were not able to get a feedback from forum. Probably someone had explored and those forum members moved on to different vehicles.
In my 2nd Gen Prius when I had my battery reconditioned and he mentioned there are kits available on ebay which is sued in Prius Japan and when we modified the prrius with the Japanese kit we can get mileage improvement of upto 50 miles.
Let me see if I can get hold of him to see if he can throw some light.
RadiantX45 (07-28-21)
Questions about B Mode
When to use B Mode
Use the B position of the Mode Selector Lever in exactly the same circumstances as you would change to a lower gear to slow down a conventional car. If you are going down a long and steep hill, controlling the car's speed using only the brakes can cause them excessive wear, get them hot and may also tire your foot. The solution in a conventional car is to select a lower gear. The engine then spins faster and the energy it takes to do this holds back the car. Less brake pressure is needed to maintain a slow rate of descent. The Prius, however, has no gearbox in the usual sense of the term. Toyota have made special provision for engine braking and to activate this you put the Mode Selector Lever in the B position. By a special configuration of the motor/generators, the engine spins and helps hold back the car just as in a car with a gearbox (see How B Mode works, below).When not to use B Mode
There is no benefit to using B mode in a situation normally calling for the use of the brakes (except one, see Advanced uses of B Mode below). If anyone, even someone who should know what they're talking about, tells you that in B mode you recover more charge to the battery, they are wrong. You recover less for the simple reason that the purpose of B mode is to throw energy away by spinning the engine. The B does not stand for Battery, it stands for Brake. However, as far as I know you will not hurt the car by using B mode inappropriately. If you press the accelerator, there is no difference between B and D modes. So, if you don't care about recovering braking energy to the battery and you get a kick out of flipping the Mode Selector Level to slow down, by all means do so. Just don't be surprised if other Prius drivers roll their eyes at you.Advances uses of B Mode
There are two situations in which B mode has been found useful other than descending long steep hills.The first is in slow descents of bumpy roads when you might not normally think of using engine braking. What happens in such a descent is that the car's traction control system disengages the regenerative braking system. This means that you are not recovering very much of the energy of the descent as charge in the battery. You won't hurt the car and there is no need to do anything about this except to brake a little harder, which you will do automatically. But, if you want to recover as much energy as possible, you can switch to B mode. A side-effect of the way in which B mode works causes an increase in battery charging at lower speeds when regenerative braking is disengaged. Note that if regenerative braking were to operate, for example if you reached a smooth section of road, you would get the most regenerated charge by switching back to D mode and increasing brake pressure. It may be necessary to release the brake for an instant to let regenerative braking reset itself.
The second is in stop-and-go traffic queues. Normally, when you move the car forward you will use battery only mode and the engine will not start. After a while, however, the battery charge level drops and you will find the engine starting for each short movement and then shutting down. There is nothing wrong with this, but if you find it annoying you can switch to B mode during a forward lurch. When you come to a stop, the engine will continue to run and charge the battery for a while. Why this happens is not understood.
https://prius.ecrostech.com/QandA/BMode.htm
B-mode made clearer
There is a lot of mystery about the "B" shift selector position in thePrius. The official name for it -- Engine Braking -- should provide a
first hint as to what it is really for. Page 137 in the '04 owners' manual
spells it out fairly clearly, in fact. But somehow a whole body of mythology
about "more regeneration" and extra battery-charge magically appearing from
nowhere has sprung up since, and really needs to be permanently debunked.
In the smallest possible nutshell, "B" mode is designed to WASTE some energy
that the car cannot recover and store. But to fully understand "B" mode one
must also take numerous other running conditions into account -- speed,
temperature, battery state of charge [SOC], brake pedal pressure, etc.
A preliminary to this was originally posted at Priuschat on Sep 20 2005,
but was subsequently lost in the Great Database Fire. In recreating the
information, several other posts and bits of mail were pulled together and
rewritten. This is long and detailed and hopefully not *too* technical,
but tries to cover everything known and verified about "B" mode. It is
also worth reading Graham Davies' explanation, at
http://prius.ecrostech.com/QandA/BMode.htm
A few basics must be understood up front:
The job of "B" mode is to help stop the car, not to save or
recover energy. In fact, it largely throws energy away.
The difference betwen "D" and "B" only appears during
decelerative coasting [no pedals pressed at all] or actual
braking. When accelerating or just maintaining speed,
"D" and "B" produce the same behavior.
All shift positions, with the exception of "P", are simply
electrical states within the control computers. In "P", a
locking pawl engages gear teeth to lock the front wheels
against turning, but that's the ONLY mechanical change.
Regenerative braking really has nothing to do with the
physical wheel brakes on the car -- the regenerative and
friction systems certainly cooperate closely, but they are
separate systems. "B" mode has nothing to do with the
physical hydraulic brakes at all, other than that the two
systems can combine forces to help slow the car.
Nonetheless, hydraulic braking, regeneration, and "B" mode are really all
parts of the *overall* braking functionality. A good overview of the
braking systems in both the '04+ and earlier "classic" Prius is in the
technician-training material on hybrids available from Toyota's Techinfo
site, in section "T072 Chapter 6 Brake system" and in the file
ileaf/techtrg/techtpdf/techtrg/techtrg/cours/section6.pdf ...
which is mirrored temporarily at
http://techno-fandom.org/~hobbit/car...s-section6.pdf for
reference. It does not really explain "B" mode well either, and in fact
this document may be one of the sources of confusion -- where it says
selecting "B" ... will maximize regenerative efficiency
and is useful for controlling speeds downhill. In "B"
mode about 30% of the energy is recovered.
This is very misleading, because what it does *not* say is that in normal
"D" mode with proper braking technique, considerably *more* than 30% of
stopping energy is recovered! I think they meant "30% of the possible
energy recovery" that would otherwise happen in "D" mode, but something
got lost in translation.
Going back to the original definition of "B" mode -- it takes energy to
turn a car engine that is otherwise not running. Friction in bearings
and pistons and cams can be significant, as anyone who tries to turn
an engine by hand is aware. But more significant is that it takes energy
to pump air through the engine -- without fuel and spark, an engine is
really nothing more than a big air compressor. The amount of energy
needed to keep all that turning and pumping is what causes the "engine
drag" felt in conventional cars when the accelerator is released. And
if the transmission is geared down, the drag effect is more pronounced
because the engine must then spin [i.e. be pulled around against air
and mechanical resistance] that much faster.
In the Prius, however, under most normal conditions when the accelerator is
released the engine shuts down entirely and leaves the car in electric-only
mode. This would provide no engine-drag, so the Prius fakes a drag feeling
electrically by having the main electric motor-generator [MG2] generate some
current and thus present an energy load against the turning wheels. Above
41 mph, the engine does still spin, but it is not fed any fuel or spark and
the valve-timing is changed so that the air-pumping loss through the engine
is minimized. Electrical energy is still drawn from the wheels by MG2
regardless of the car's speed -- and the most useful place to send that
energy is to store it in the battery. This is a regenerative stopping
force, but in "D" with no brake pedal applied it is a fairly weak force --
not one you could really consider as "braking". It is not enough to prevent
the car going faster and faster down an appreciable hill, for example.
Regeneration current into the battery in this state is between 10 and 20
amps [out of a possible 100] depending somewhat on speed -- at 200 battery
volts that's still 2000 or 3000 watts or more, which is quite a bit of
energy from just gently resisting the car coasting along!
Gently applying the brake pedal increases that regeneration current, up to
a maximum of 100 amps -- 20 kilowatts -- and in the '04 and up Prius, does
not use the physical friction brakes at all until they are needed. That's
like the motion of your car powering four electric dryers at once, and
it's *all* going into the battery pack! But even 20 kilowatts cannot always
provide enough stopping power, especially at higher speeds, so anything over
and above that must be supplied by the friction brakes. The rest of that
energy then gets wasted as heat in the rotors and pads. But what if you're
driving down a long, steep mountainside? Maybe that 20 kilowatts of
battery-charging energy is enough to hold your speed back -- for a while.
But eventually the battery gets full -- actually, to the 80% charged limit
enforced by the computers -- and to protect the system, charging current is
eventually reduced to zero, and the only thing now holding the car back
from disaster is the hydraulic brake system -- which is now rapidly getting
hotter and hotter and reaching its own limits on how well it can continue
stopping the car. Brake fade, when the parts cannot absorb or dissipate
any more energy, is a very real problem on mountain roads.
Enter "B" mode. As in, "trucks use lower gear". By forcing the wheels
to spin the engine and pump air, a good deal of that energy can be turned
to heating the air going through the engine instead of heating the brake
parts. Since fresh air is always coming into the engine, having it leave
as much warmer air provides a convenient place to dump excess energy.
In a conventional car the wheels push the engine around through the
transmission, but the Prius needs to help that process out a little bit
by actually having its combination of electric motors spin the engine.
In this case, the valve-timing in the Prius engine is advanced to increase
the amount of air taken in and the suction against the throttle flap -- which
uses much more energy than the coasting-in-"D" scenario above. Either way,
stopping power now comes from a combination of things and the burden on the
friction brakes is greatly reduced, allowing the hill to be descended safely.
"B" mode also increases regeneration current to 30 - 40 amps with no feet on
the pedals, so the part about "more regeneration" is somewhat true. That
is one of several mechanisms used to increase the "drag" feeling. That
level also varies with the car's speed. However, the car's movement is
often supplying much more energy than that, so what isn't captured in the
battery is wasted by flailing the engine around. This is *not* more
efficient usage -- it is almost always better to gently brake in "D" for
maximum energy recapture, if you have room ahead to do it. This is one of
the common misconceptions about "B" mode -- it does not create more energy
from nowhere, despite how much it may feel like traditional "gearing down"
and using the brakes less. In fact, for those times when the rolling *car*
has too much energy for the battery, "B" helps get rid of it. In addition,
using the brake pedal while in "B" mode behaves exactly the same as in
"D" -- if there's any capacity left in the battery, the system tries to
regenerate up to the same limit of 100 amps, above which the friction brakes
are brought in to help -- the only difference in "B" that the engine is also
spinning away against air pressure. Again, the hydraulic brake system does
not care if you're in "D" or "B" -- it just supplies what the rest of the
systems cannot.
The only time the physical brakes are used *by preference* is during a
panic stop, when the pedal is suddenly slammed down. The system senses
this fast rate of change and immediately brings in the hydraulic brakes
for faster and safer stopping with all four wheels. "B" mode makes no
difference there, either. And of course all regeneration quits at less
than 6 or 7 mph, when the motors aren't turning fast enough to provide
useful power -- the physical brakes handle the last part of stopping.
Many people can feel a sort of braking "sag" at the transition, although
Toyota has managed to make that fairly smooth and seamless.
If one thing must be understood here, it is the distinction between the
BRAKES and the total BRAKING SYSTEM. The hydraulic friction brakes in each
wheel cannot supply energy -- they can only waste it, throwing it away as
heat to the air around them. Parts of the braking SYSTEM -- that one could
consider as including the driveline and electric motors, the hybrid and
braking computers, the battery -- can work together to recover energy and
direct it around to where it needs to go. But when someone naively says
"the brakes charge the battery", that's really rather wrong.
Now with all of that said, there are a few funny quirks and factoids to
know about "B" mode, none of which really help increase fuel efficiency
but are interesting to know about regardless. In general, the amount of
extra resistance given by "B" mode is sort of staged upward depending on
the car's speed and how charged the battery is. Some of these conditions
can be utilized in entertaining ways.
Under 20 mph, if the engine is not already running and your foot comes
off the accelerator, B mode simply regenerates reasonably heavily [30A or
so] into the battery. This drops off around 12 mph to a lower current,
and is then similar to being in D until regen capability kicks out entirely
around 7 mph. So between 19 and maybe 10 miles per hour, you can use "B"
to slow down in an energy-productive way, and essentially drive around in
electric-only mode with one pedal -- but be careful to not do something the
person behind you doesn't expect without showing brake lights! As soon
as you crest 20 mph, however, the engine begins spinning -- to enable the
system to dissipate more energy at the higher speed.
If the engine is running and you come to a standstill while in "B" mode, the
engine *stays* running -- just idling. The reason for this is not really
known, but it is a way to continue warming the engine when it's cold out and
you're stopped in traffic. Driving around in "B" during warmup also tends
to charge the battery a little faster, since electric-only mode is avoided,
but again at the expense of burning more fuel to do it. Engine start/stop
transitions are avoided. Sometimes this state feels more surefooted and
responsive in snow and other tricky conditions. People who have autocrossed
the Prius have recommended staying in "B" for better and quicker control --
having the driveline "fall on its face" the instant your foot comes off
the accelerator pedal may be desireable behavior at times. This may feel
familiar to some EV drivers, where regeneration control all comes from
releasing the go-pedal in controllers without integrated braking features.
Fuel usage in "B" is somewhat mitigated by the fact that when decelerating
above some nominal speed, somewhere around 17 mph, no fuel is sent to the
engine and it just spins "dry". It's still wasting energy and slowing the
car, but there's no reason to throw away gas along with that. This is
sometimes called "fuel-starve" mode, and is also used in some conventional
cars during high-speed coasting conditions.
It is difficult to tell when that 100 amp battery-charge limit is exceeded
without extra instrumentation. When the battery pack is cold, that limit
is actually lower -- down around 50 amps, until cabin heat begins to
circulate through the battery pack ventilation ducts and the pack self-
heats a little from being used. The system is quite good at protecting
the battery against things like overcurrents, and sometimes that gets in
the way. Slowing over bumps often confuses the regen mechanism, which can
sometimes be felt by the seat of the pants as that same little braking "sag"
right after the bump. The system has given up on regen at that point, and
is now only collecting the "coasting" baseline 10 amps of battery current,
and using the physical brakes almost entirely to stop you. Recovery from
this situation appears to be time-based, so your best bet at that point is
to slap it down into "B" for the duration of that stop since while you may
spin off some energy in the engine, regen current *will* be a bit heavier
than in your now pathological D-but-confused braking state and you might
recover a tiny bit more energy. But don't get into the habit of using "B"
to slow down unless you really need it -- that's sometimes hard to get used
to if you come from ingrained years of "gearing down" in conventional cars.
Many strange things happen when the battery pack gets up to "eight green
bars" full level. The hybrid system begins doing several things to pull
a little energy back out of the pack -- the engine will tend to spin in "D"
mode even at low-speed, low-demand conditions, in fact just about in the
same way as "B" mode does when the charge state is more normal. If "B"
mode is selected in the full state during coasting, then the engine *really*
screams and even more energy is pumped away. So while all the energy of a
long descent cannot be captured, speed can be controlled in some interesting
ways by creative shifting between "D" and "B" even after the pack is topped
out. When the car is stopped, the engine may randomly start and stop several
times -- the theory is that the system is ridding itself of excess battery
charge to get it back within safe limits. You only really get 600 watt-hours
full range to play with, which isn't a whole lot. Still, the car really
goes out of its way to make sure there's plenty of stopping-power reserve
on tap if the driver needs it. And there's no question that larger battery
packs would give a much wider range of energy-recovery -- possibly enough
to hold an entire mountain descent's worth. Some of the extra-battery
experimenters have successfully done that, in fact.
It is said that the early Japanese "hypermilers" used B mode to gain fuel
efficiency. There is no advantage to be achieved by this with the current
generation of Prius, but in the earliest Japanese models and the "Classic"
imported to the US for 2000-2003 the regenerative braking system is a bit
more crude and brings in the physical brakes much earlier in the game even
when they're not necessarily needed. With higher-power-capable motors and
the reworked "by wire" brake system in the '04 and since, this is no longer
relevant since little or no pressure is sent to the wheel brakes until the
system has extracted as much regeneration as possible. However, those early
and somewhat vague stories could be another source of myth and misinformation.
Help clear up some of the confusion about B mode. Tell other owners [and
dealers!] who don't necessarily read this stuff why "B" is NOT saving
them any gas.
_H* 050920, 060128
The following 4 users liked this post by ukrkoz:
Feel like I got my Phd in B-mode now.
Enjoyed it!
