Serviced at Dealer Today
Today (12/10/2021) the dealer serviced my car and did the following things"
Engine Oil & Filter Change
Inspect and Top-off Coolant and Windshield Fluid
Navigation Map Update and Calibrate (PT219-GEN09-21 GEN 9 V21.1)
Replace Fuel Pump - Lexus Recall Campaign LC0103 21LC01
Tested 12 Volt Starter Battery - Test Results: Rated 450CCA - Measured 422CCA Voltage: 12.63V - Reserve Health: Good
Customer Requests: NO CAR WASH - Return to DZ Area, Do Not Mess with Tire Air Pressure, Do Not Check Cabin Air Filter, Do Not Check Engine Air Filter, Do Not Put Oil Change Reminder Sticker on Windshield.
Note: Passenger Side Rear Shock Blown* - Replacement Part ordered 12/10/2021 - Will be in next week and will email/text when in for installation.
* Lexus Technician said it is common for even new car AVS Shocks to leak and need to be replaced. (Interesting!)
► Get your low pressure fuel pump replaced under the Lexus Recall Campaign LC0103 21LC01 - If you don't, your car may stop dead in its tracks!
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
It's recommended to be changed at 36 months or 30,000 miles. Being that the car is only 36 months old and only has 5,700 miles on it I don't think it's needed - though I'm sure some people would say it has moisture in the brake fluid after three years - I'm saying it's been in the dry climate of Las Vegas, NV so changing the brake fluid is not needed.
► Get your low pressure fuel pump replaced under the Lexus Recall Campaign LC0103 21LC01 - If you don't, your car may stop dead in its tracks!![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
I hope this is just a single random part failure and does not become an issue for Lexus. In some manufacturers these expensive suspension repairs have an impact on model reputation and resale values. For example Mercedes SL and S class with Active body control and others like Bentley with air suspension.
https://www.clublexus.com/forums/gs-...k-options.html
https://www.clublexus.com/forums/gs-...ek-review.html
bclexus (12-16-21)
Good you had the car looked over. No surprise about the GS struts.
Yeah, jgscott - the Lexus technician doing the work on my car is a lead Lexus technician and he is excellent at always carefully checking everything just like it's his own car and not overlooking anything. He's quick to inform me through the service manager he works under if anything is amiss. That's why tomorrow I'll be giving him an envelope with a special Christma$ 'thank you' gift to show my appreciation that will be sure to put a smile on his face...
Aegean, with all the many threads here on CL talking about leaking or blown AVS struts I think it has likely already become an 'issue' for Lexus to some extent. I don't know how Lexus explains why a strut fails in my case with less than 6k miles on the car of easy driving. Clearly the strut's seal seems to be the culprit. Quite costly for anyone with their vehicle out of warranty!
Who knows, maybe Lexus will initiate a mass recall to replace both front and rear AVS struts on select models and model years. That would be nice!
Over the past few days I've noticed a clunk sound at random times when driving over small inclines when the suspension typically loads (dampens) and then rebounds a little. However, if I put the drive mode in Sport+ it seldom makes the clunk sound. So, I guess the Sport+ AVS adjustment helps rid the leaking (blown) strut of its internal lack of dampening or looseness to some degree.
jgscott (12-17-21)
Good you shared this with other here, I have been doing this for quite some time at many shops always.
On the Struts, so a Member here pm'd and gave me the Pres of SE Toyota/Lexus email for his assistant. I sent a email about the Struts not asking for anything just a FYI to them about others and the GS pre-mature Strut failure. So one day I get a call from his assistant. I explain to her that I had called Lexus customer service and that they told me to go pound sand, but that there was a problem with those Struts for many. She said it was good that everyone call Lexus customer service to let them know regardless. As a result, I was surprised one day shortly after I got a email with a large Lexus Dealerships Service Credit amount to use at any Lexus Service center. I tried here in many threads to tell other to call Lexus customer service and report the Strut problem when they had it so that they would maybe do something about it for others.
In the threads some said yes, some said np, I had a feeling that many had no idea and had not really had a check out. Because as you just substantiated its even on low, low miles just a few years old GS's also, and Not just the 350 either. So again, if anyone has this problem do call Lexus Customer service and at least report to document. Lexus quoted me $800 + for one Strut and 2 others were leaking too, just not as bad. As if they were not going to get worst.
bclexus (12-17-21)
So, I had the rear passenger AVS strut/shock replaced today.
![](https://i.ibb.co/YpZsMyN/IMG-0232.jpg)
mrBillFL
ES - 6th Gen (2013-2018)
20
03-26-15 08:40 PM
