'Customize' Drive Mode
Does anyone have the 'Customize' Drive Mode setup and used regularly? If so, I'm curious to know what your customized setup is. Please share...
I presume if the 'Customize' Drive Mode has not been setup there is no difference between it and 'Normal' Drive Mode, correct?
Hues10 - I don't know when Lexus added the Customized Mode. At least on my 2018 GS 450h the Customized Drive Mode is accessed by pressing the Normal Mode switch a 2nd time.
Normal Mode/Customized Mode:
Normal mode and customized mode are selected by pressing the driving
mode select switch. Each time the switch is pressed, the driving mode
changes between normal mode and customized mode. When customized
mode is selected, the “Customize” or “CUSTOMIZE” indicator will be illuminated.
Originally Posted by bclexus;[url=tel:11186492
11186492[/url]]Does anyone have the 'Customize' Drive Mode setup and used regularly? If so, I'm curious to know what your customized setup is. Please share...
bclexus (12-22-21)
The Customized mode was added in 2016.
I have mine set for the normal HVAC and engine parameters, but the stiffened suspension. I rarely use it. I usually just go straight to Sport S+.
The following 2 users liked this post by JDR76:
bclexus (12-22-21),
Im2bz2p345 (12-22-21)
Imho, it would have been more useful if instead of a "Customized" drive Mode, Lexus allowed you to set a "Default" drive mode. I've read about some folks that immediately after starting their car, they change the drive mode to their preferred option, so this would be beneficial for those that want to drive in a certain mode right away.
~ im2bz2p345
~ im2bz2p345
bclexus (12-22-21)
~ im2bz2p345![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
~ im2bz2p345
