2022 NX 450h+ Charging findings
#61
Have you looked into rebates for installing the charger? Also, it might be cheaper than you estimate to install the charger in your garage. If you have an electrical panel/sub-panel there you might have enough space (or be able to make space) for less than that and then it should just be a breaker, the wire, and the outlet..it is possible an electrician quote may end up being less than you expect. Also, Costco sells the Juicebox charger I bought for less than regular retail..and I've seen them on sale occasionally. Still won't be free, but parking in the garage vs. the park is worth something
#62
I installed chargepoint charger and I'm on the Tou 1 plan for sdg&e. cost per night is roughly $1- $2 per night. For our house it doesn't make sense to go to EV pricing rate as raises the on-peak cost goes up. I believe the weekday super-offpeak 12am to 6am is .23kwh and if you the ev plan is .16 kwh.....on-peak (4pm-9pm) goes from something like .58 kwh to .64 kwh
#63
#64
We have chargepoint at 2 offices so I figured I would make it easier on myself. I think chargepoint is the most predominant charger in at least CA (could be wrong). App is pretty user friendly, set my schedule to super -off peak and I get an good idea of the cost. I elected to go with 50 amp circuit to 14-50 plug. Figure it's the most common and I can swap it out pretty easily if there is an issue.
#65
One nice feature of the Juicebox (not sure if the Chargepoint has it) is that they can share the same breaker/line and intelligently share max amperage. This only matters if you have 2 chargers and can't dedicate the full 50amps to each one on your panel. We're thinking of getting a second PHEV or EV, and it would save me a bit of money to use the same circuit, so this feature is potentially very useful to me.
I've also seen them at Costco for even cheaper recently, but that version had a slightly shorter cord and seems to be out of stock now.
Both the Chargepoint and Juicebox seem to have similar positive reviews, with some sites liking one or the other. My recommendation is to find the one that is in stock and has the best price (if significantly different) and just check if a few feet of cord length matters to you.
#66
I went with Chargepoint here in Los Angeles. I spoke with a few different electricians when I was getting quotes for installing the charger, and Chargepoint is the one they all recommended. We hardwired it rather than installing a plug. We do not get any break on our electricity rates, but DWP will reimburse you $1000 for the charger and installation.
#67
Thank you so much to the OP and everyone contributing questions, opinions, and answers.
I went with ChargePoint Nema 14-50 plug. I paid an electrician to run the wire from the electrical panel to my garage. He ran the conduit outside the wall and drilled it into the garage. Cost 1000 in SoCal for wiring, new breakers, consolidating, and moving breakers. He thought Nema 6-50 outlet was good enough and quoted a cheaper install. As many have said, everyone has choices to make; I read that Nema 14-50 outlet is preferred by Tesla. I am not a tesla fan, but they are dominant. I wanted to have some future proofing here.
#68
Thanks for info You have great charging rate
Thank you for your info. I too have a new 450 But not as lucky as you with your charging rate. I live in CA SF bay area and the best rate available is .25KWH from midnight to 3Pm and thats the best rate for elec vehicle charging But with comes with that is a higher rate of .54 KWH for all other hours of the day. You obviously do not live in this crazy socialistic part of the state Thanks again for info
I've had my car now for about 4 weeks and really like it. It's the best Lexus I've had so far. Regarding charging the car, here is what I found:
1. Using my Lexus 6.6 Kilowatt On-board Charger with the Lexus charge cable plugged into a regular GFI socket in my garage worked fine but took about 11 hours to charge.
2. Using the same Lexus 6.6 Kilowatt On-board Charger with the Lexus charge cable with a 240V adapter (purchased from EV Doctor in Carlsbad, CA for about $70) worked great and only took 5 1/2 hours to charge. I had to have a 240V 50amp socket installed (about $500).
3. Using my Lexus 6.6 Kilowatt On-board Charger with a new Chargepoint Home Flex charger system (that includes a new, heavier cable) that mounts on the wall and plugs into a 240V 50 amp socket only takes 2 1/2 hours to charge. The Chargepoint charger costs $753 but is great quality and easy to install in minutes. Their app told me my charging cost me about $1.32 each time I charged my car (I signed up for the EV Charging Plan with SDG&E to get a $.10/kilowatt rate during 12 am and 6 am plus weekends and holidays).
The Lexus app under ECO History shows me getting 175 MPG right now which should increase depending on how much I can drive in EV mode.
Great car with a lot to learn...
Lexus app showing 175 MPG (should get better)
Chargepoint charge cable plugged in
Chargepoint system mounted on wall plugged into 240V socket
#70
I also want to thank everyone for their comments and opinions. I went with the ChargePoint Home Flex, NEMA 14-50 Plug. Cost $1000 to install in my garage.
I see the charge to full around 2.5 hours from the 50A circuit/breaker. The App is estimating the cost per charge based on the SCE plan. Costing me $5-$6 per charge. I want to check this figure but haven't had a chance to understand if this is correct. Honestly, if gas is $2-$3 per gallon, would I charge the car if electricity is costing me double? Big companies get you one way or the other.
#71
- Your car can usually go about 3-4 miles per kWh of charge. So using quick numbers, you would need about 10 kWh to fully charge to 40 miles. I'm with DWP, and the most expensive tier of electricity is 0.327 per kWh. So 10 x 0.327 would be $3.27 for a 40-mile charge.
- If you assume you can go 40 miles on either 1 gallon of gas or a full charge...then it's about half the cost if you use electric vs gas.
#72
PHEV - Charging gidelines
Hi
I took Lexus NX 450h+ from northside Lexus, Houston.
As per instruction from Lexus , I am supposed to use or input 32A with 240V.
I bought ChargePoint Home Flex ( $750+) as per Lexus recommendation.
When I set up on chargepoint App I do not see 32A. I see 40A or 50A.
Can anyone suggest which amperage I have to use?
Can we configure to 40A even though Lexus says 32A? Any risk to battery life?
Thanks in advance.
Murali
Thanks in advance.
Murali
#73
Hi
Thanks in advance.
Murali
Thanks in advance.
Murali
The car can only charge at a maximum rate of 6.6kW, which is about 28A, which is why Lexus recommends at 32A charger at minimum. The car will not draw more power than the 28A and it doesn't matter if you set the charger for 40 or 50A. You should set the charger to the maximum your electrical setup can handle in case you ever plug in a car that can draw more than your NX.
#74
Your app is showing the possible options for maximum output from the charger (40 or 50A) which you can limit if you need to based on your electrical panel/wiring.
#75
As far as your app reporting miles, you have a few things going on here. These apps use a generic estimate of miles/kW that might not match what you're actually getting nor what Lexus claims based on the EPA testing rules. I use a different charger brand and have the ability to change the miles/kW to match what I've actually been getting in the car vs. what they think the model gets generically. Check your app to see if you have that too.
Secondly, you may not be bringing the car back at the same charge level each day, and I'm guessing the app is basing its estimates on how much it added. It doesn't get detailed charge data from the car.
Also, the charger only knows how much energy it sends to the car, not how much was actually added to the battery capacity. There's loss during charging, the system (onboard charging system, batteries) isn't 100% efficient. I've calculated it to be about 20% loss, so when I want to add 10kWh, I set my charger app to send 12kWh and start the charging with enough time to finish sending 12kW. Your app may be either adjusting or basing the miles on the wrong # because of this, you'll need to adjust the miles/kW to take this into account to be more accurate.
Finally, your actual driving experience will result in different miles/kW than other people, so any kind of average or EPA # may not apply to you.
Short answer is the apps use lots of estimates and base their estimates of numbers that don't match your reality. If you the ability to update those numbers in the app to match your situation you may get closer to reality.
bladest
12-25-21 07:01 PM
Curated Content Editor
03-26-20 12:15 PM
