Mounting radar detector nx450h
Anyone planning to mount a radar detector in your NX? I usually mount them to the rear view mirror with a Blendmount. The spindle for the rear view mirror om the NX450h is much different than in any car I've owned. It drops straight down from the housing, seems kind of thin with the thick mirror wire clipped to it. Has anyone tried using a Blendmount or other mount yet to attach the detector to the mirror? I'm not planning to tap the mirror power. I'll just power from the OBD port and hide the wire under the triim.
Blendmount site shows a mount for the 2022 NX that seems like the others, requiring a thicker spindle with an inch of room needed. Doesn't look like my mirror unless it is different in the other NX models or mine's different because I have the digital rear view mirror option.
Post your solution once you have it, please. I'll be (hopefully) trying to figure out the same thing in about a week or so. While every detector is different, you might come up with a better solution than I will.
yayeeeet
03-15-21 07:37 AM
roman1
10-17-17 03:42 PM
