Several "DISLIKES" so far on my 350h premium package
#31
But can you reset the ave mpg for when after you refuel? I am not sure about trip A and trip b because I never used thst. Only reset mpg after each fuel up. Can you do this? Just press ok and you will get zero.
but I guess you are trying to reset trip a or b?
#32
Coming from a 2017 CRV Touring, if I a reading these post correctly, the NX 350h Luxury I have on order will not have these CRV features:
1)No auto lock walk-away feature? I really like this.
2)When you do a fill-up the trip A adapter reset automatically to zero and MPG reset also? Lexus does not have option? Again, really like.
3) Center cluster display is large, all digital and it easily show RPM, instantly MPG and average MPG without an schooling. On Lexus data is there, just hard to see at one time?
4) The CRV allows you to do lane tracing without ACC. Lexus you have to be in ACC to get lane tracking? I almost always have lane tracing on. It works ok.
These are not showstoppers, my order will stand regardless, And some I knew already. But if they are gone,I will miss them. SAD. But I could also list the things I don't like about the CRV. And they are worst than not having an auto lock. LOL. Freezing being one of them, gas in oil dilution, no true TMPS and gives a lot of false negatives, ACC is jerky and brakes way to hard (scares the guy tailgating you), poor dealer support, no engine or display updates, and leather seats failing after 15K miles. Sad. Really looking forward to get back into the Toyota family (two Camrys). The CRV was my first Honda and last.
#33
Lungfeng, I don’t know how to reset trip a or b. In the nx350 but I will try to figure it out when I get it. I just looked at my Highlander and there is a manual button or thick needle like plastic item that you push down to pick a or b and then push down and hold to clear A Or B. I don’t think the new Lexus NX has this and there must be a digital way to do it. Sorry I did not understand your issue. I thought I knew because the info cluster on the left looks so similar to the toyota cluster
#35
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/1071x911/542dc3dd_62d7_44b5_8768_2c00644c75d2_59b290b77a9e8541156eed81e7adff954e215d9c.jpeg)
#36
#37
My Lane Tracking is on without the ACC being engaged.
KingKewl (02-19-22)
#38
Ctrips, thank you! Lungfenzhe will appreciate your post
#39
Interesting, per the 350h manual (page 368), it says it does not. I wonder if we are talking about the same thing. I think the lane departures is always on the NX as is is in CRV. I am referring to the Lane Tracing Assist driver function that keeps the car in the center of the lane when on highway. I hope the manual is in error. I don't see why you would have to have ACC one. As noted, my CRV does not require ACC to lane center.
Manual clip below"
"LTA Function● When driving on a road with clear lane lines with the dynamic radar cruise control operat- ing, lane lines and preceding and surrounding vehicles are detected using the front camera and radar sensor, and the steering wheel is op- erated to maintain the vehicle’s lane position.
Use the this function only on highways and ex- pressways.
If the dynamic radar cruise control is not operating, the function will not operate."
Manual clip below"
#40
Manual clip below"
Manual clip below"
#41
Yes@gcskoor we were talking about different systems and I hadn’t read them up fully in the manual. What I am seeing on the display are the Lane Departure Assist (LDA) and the Lane Change Assist (LDA), neither of which require Cruise Control to be on. As you say, the Cruise Control has to be on for the LTA to operate. My UX was so much simpler to understand! 😱
What I am hearing is the NX's LTA is very good- probably better than the Honda's, I hope. And the ACC is much better. The Honda's ACC will try to follow a car' speed into into to the off ramp and brakes. Sometime pretty hard. . Really bad for the guy behind me.
#42
Jawnathin
Hybrid Technology
65
03-28-22 05:56 PM
kndonlee
10-07-21 04:01 AM
