Inverter cooling pump fail
My inverter cooling pump started getting intermittent last June. It’s been good until December and failed again. Then failed again in February and then a couple times since.
Tapping it gets it going in a pinch but it was time to replace. My son did it for my on a lift at Toyota dealer where he works. Probably took 20 min.
Symptoms are obviously a hybrid error and the fans will be running on high. If you keep driving 100% power loss is inevitable pretty quickly so park it as soon as possible. Else it will stop you.
doitup (05-22-22)
doitup (05-22-22)
BlkSabbath
04-21-21 02:54 PM
Eds98LS
03-10-12 05:39 PM
