Hybrid TechnologyUnique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Hi. Does anyone has a ecm pinout of a 2006 Lexus rx400h? I am trying to figure out what wires are the knock sensor inputs on the ecm.
Thanks
This is no problem.
FYI, you don't need the full Hybrid ECM pinout for knock sensors which is good because the pinout spreads thru many different schematics, you only need the knock sensor info.
I'll post it up when I have time unless someone has it handy and wants to help.
BTW- what the issue with your knock sensors? Share the story if you like.
I recently got a check engine light, code p0333, knock sensor 2 circuit high input. I saw some videos how to cancel the defective sensor and feed both inputs pins from the good sensor. The guy that I watched was working on a 2007 rx330. the input pinout is not the same as my rx400h. t
