450H 12v battery issues
#46
I have had my NX450H+ since March and installed a “Thinkware dash camera” right away…
.I too experienced a low 12 volt battery after not driving the car for 3-4 days and suspect the dash camera draining the battery. I will be disconnecting the “park mode” on my dash camera.
my issue was with the dealer who misinformed me on how the 12 volt battery charges. They told me the 12 volt battery does not charge when plugged into the level 2 charger or when in full EV drive mode.
Both dealer statements are wrong…. the 12 volt battery most definitely charges when the EVdrive battery is charging or when driving in full EV mode…I had to research the RAVE 4 Prime forum to get this information ( note: Rave 4 Prime is the me running gear as the Lexus 450H +)
I definitely will be adding a trickle charger for longer dormant periods of non driving..
YMMV,
MidCow3
#47
Hi,
I have a 450H that was delivered to me about 2months ago and 5k on the odo. 2days ago i could not enter my car due to dead 12v. Yesterday dealership charged the battery and said i should buy a trickle charger for 175$ which i find a little absurde considering I just dropped 90k on the car 2 months ago. Lexus should really hire some electrical engineers to build in a trickle charger that charges off the main hybrid battery.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#48
Hi,
JD
#49
Can you tell us what after market 12v battery you got (brand, type, Amps)?
Thanks!
Earman (05-04-23)
#51
I just installed a trickle charger (Noco Genius2D) and even though the battery was charged to 100% a week ago, it was only around 50% today... I drive 99% on electric and mainly city driving less than 40km/day. I did not put the car in ACC mode at any time during that week. I am going to get the battery status checked at the dealership in a few days.
Thanks again for the very useful info!
#52
I have the same NX405h+, my 12V battery was dead on March 2024 and bought to Lexus DEALER for replacement with new 12V Battery...... Two months later 5/15, it is the same issue 12V drain out and dead. I just took it back to dealership today for further investigation ..... Most likely, it is design issue not because of battery or not driving long distance. Hold on for further update.
#53
This proves that driving for a long time only charges slowly and it won't be enough of the power lost during startup.
FinnegansWake (05-17-24)
evchao
RX - 3rd Gen (2010-2015)
01-28-22 12:49 PM
