Winter Tires/Rims NX350h - what's a good plan?
#241
#242
#243
But aside that light, it's been pretty good.
#244
For my NX 450h+ the wheels I got were from Toyota/Lexus so the bolthole dimensions will be standard for them, 5 x 114,3 mm (dia). In my experience, the bolts used have a head with a curved underside that is like a built-in washer. The curve matches the countersink in the holes in the wheel and is there to make the bolts self-centering which pulls the wheel evenly around the bolthole circle. Old-style steel wheels had nuts with a curve under as well for the same purpose. A bolt with a flat washer will not tighten properly and the wheel could be marginally off-center and will never balance on the car even if perfectly balanced off the car.
It is very important to get wheels that can take a high load, because the NX series is quite heavy, especially the plug-in. To be absolutely correct, the wheels should be type-approved for the car, but I think that that information is only available on manufacturers' websites and I don't think most people bother, they just buy a good quality wheel with the correct load rating. If you look at sites like CMS er Dezent you can see the type of information available.
FInally, sorry this is so long, the center bore should match the car, most Toyota/Lexus are 60,1 mm, but you can fit a wheel with a bigger bore by using a plastic or metal ring that is tailored to the sizes. Keep in mind that a big bore means less metal roung the boltholes.
#245
Did you look around at different winter tires etc. Or just stuck with what the dealer offered. I’m a big Halikappeti winter tire fan
reereeyyz (03-05-23)
#246
#247
Thanks for all the great info and pics everyone. Here is what I ended up with.
Went down from 20" OEM Run Flats to 18" for the winter.
Autobahn DW48 Satin Black wheels (DAI Wheels)
Yokohama IceGuard G075 ($70 mail-in rebate promo)
Aftermarket TPMS (sensor's cloned from OEM's)
Had them installed here just a few days before Vancouver had it's most embarrassing display of how the various municipalities handled our first snowstorm this year.
Stay Safe Everyone!
Stay Safe Everyone!
#248
Do you mind PM me where you get the set up? I'm from Vancouver too and your set up look awesome on cloudburst grey which is what I will have in few months. Would love to prepare myself for the next winter, I should receive my car before this summer (or so I hope since the build day is March 25 in Japan). Thank you so much!! Yes, I agreed.... our municipalities are embarrassing. It took me 3.5 hours to drive from downtown Vancouver to YVR that night....
What did you order that is made in Japan?
#253
I'm still debating if I want to put a deposit on the NX450h+ myself since it might end up taking 3 years at current wait times... But I think I'll hold off while I see what the market does over the next few months.
Anyway, winter would soon be over... You should get a good deal and some discount when you're ready to purchase.
#254
I try...😁
I'm sure hope the interest rate will adjust along with the winter package discount coming along but cannot hope for too much at the same time
#255
It's refundable, so why not? I think I read an article somewhere recently that Toyota is recovering and going to up the production for the global market. Worth a try or put a deposit on RZ?
