eCVT issue or normal behavior ?
7th Gear
Other user mentioned this earlier and I have now the same observation, when doing highway speeds and letting off the accelerator and then getting back on it, it is like going from neutral to drive at 60+ and i can feel jerk from tranny, imagine peacefully cruising and all of a sudden quickly accelerate type of jerk. Other than that, it is fine
Anyone had that experience or resolution ?
Never had that experience with my GSh. Sounds like it may be a bad engine mount or tranny mount.
7th Gear
I have definitely never experienced that behavior with my GS 450h.
Update
Turns out it was wrong ATF fluid. When I went to change it, old one came out in darkish translucent colour not like dark ping that Toyota ATF WF should be. Smell was also more like standard ATF thats going to ZF 8sp. Transmission. I did drop and fill with WS fluid, reset the learnt values. Car def. feels different now. Will do another drop and fill in a month or so.
Stupid fu//ing russian that owned the car before me, must have tought same fluid is same fluid what difference it makes.
Forum Administrator
Peter, why aren’t you using your original account?
Forum Administrator
Which one do you want to keep? I’ll merge them
