Longevity of Traction Battery
Hello everyone,
I wanted to find out how many clublexus members are currently still using their original traction battery on their Lexus RX450h and what mileage they have on their RX450h. I currently have two 2011 Lexus Rx450h's that are on their original Lexus RX450h traction batteries. The first RX450h has 161K and the second RX450h has 126K miles on the odometer. I have had the 12V battery replaced on both vehicles. I am just starting to investigate options for replacing the traction battery once the original traction battery dies out. I currently have found a national battery shop called Greentechauto in Clearwater, FL and another local hybrid battery shop in Brooksville, FL. Replacement traction battery links are listed below:
Greentecauto
https://www.greentecauto.com/hybrid-...-2014-new-cell
Affordable Hybrid Battery repair of Tampa Bay
https://affordablehybridrepairtampabay.com/
Greentecauto
tempestv8 (02-18-23)
Wow, a traditional Lead Acid 12v battery lasted 12 years! As you all likely know,
the Toyota/Lexus warrantee on Hybrid batteries was extended from the 8 year/100K mile
to 10 year/150K mile period starting with the 2020 model year. This covers both the
Nickel Metal Hydride that has been fitted since the original Prius and the newer models
that come with the Lithium configuration.
NdYAG (04-20-23)
I'm going to chime in with a "none of the above". Heat is the real killer. Hot heat, the worse kind. Charge/discharge cycles (which can be equated to mileage) is not really a big issue because these batteries don't go thru complete charge/discharge cycles. The amount of charge/discharge allowed by the vehicle compared with maximum rated battery capacity is very small (the in-vehicle battery charge displays don't show the rated battery capacity, only the small range in which the battery is allowed to cycle). Time, well that implies that just sitting there does damage. Aside from the fact that NiMH do have a self-discharge rate which is easily overcome by an occasional charge (ie start the car). But heat, yes, the heat is what is going to not only reduce effectiveness, but also risk over pressuring the cells. There is a reason the battery pack has quite large vent motors in them that can draw nice A/C cooled air (in theory on super hot days) from the cabin. Not sure if anyone has ever heard these vent motors gong full blast (I used an ODB tool to command them to full speed just to see), they sound like a hurricane is under the back seat.
I believe the true limitation with these vehicles is everything “other” than the main traction battery.
Major suspension components, exhaust/emissions, engine, major braking/anti-lock components, and rust will more likely diminish the useful longevity of these hybrids.
Even then, most of the “others” mentioned above have a surprisingly great reliability/longevity history so far.
The first thing that non-hybrid driver/owners seem to ask is “just wait till that expensive battery needs replacement”.
I tell them, it’s the last thing I’m worried about.
The following 2 users liked this post by chrispy:
NdYAG (04-20-23),
RadiantX45 (02-18-23)
we are flipin odometar almost 330 000 km on 2010 rx450h model.our routine is that we clean every month 3 went ports under rear seat to keep cold air intake free of any dust or debri monitoring temperature on all 3 cooling fans inside hybrid battery to be within 5 deg of difference between them ising dr prius app and very nice obd linx blue tooth reader super fast from ebay or amazon. and recharging AGM battery from time to time with slow trickle charger schumacher .one time small battery 12 v was replaced because remember all your acessories running of that small battery .only problem now is how to replace last 2 spark plugs which heat recovery unit is covering .we posted thread with that issue and looking forward to solve it soon.
