Octane for RX350h?
#61
Its shocking this is in the manual, to me this is ambiguous. I'm a little upset that they say "you can run either fuel" as It leaves a lot of room for people to interpret it their own way.
Anyway will run 87 and cross my fingers the computer runs a similar tune as the ES300H.
think more about what brand of toothpaste I use.
#63
These discussions are amazing to me. As stated above, the manual clearly states 87 is the minimum. This is not ambiguous at all. Why would the fact that you can run either gas bother you? It gives you choices. Choice is always good.
#64
I think part of it is the “I just spent a lot of money on a Lexus so I can I use the cheapest gas possible even though they recommended higher priced gas?” Either they over extended themselves or they’re mostly frugal.
#65
#67
By the way, I ended up buying an Audi Q5e. Plug in hybrid.
#69
Personally, I would only run 91 or higher in the RX350. 91 isn't just recommended like with the RX350h and RX450h+, it's required. The manual specifically calls out that the engine may be damaged and the warranty may be voided by the use of fuel with an octane of less the 91.
If you want to run lower octane fuel, I'd recommend against the RX350 and suggest the RX350h instead.
My perspective: I run 91 in my 350H. Approximately 30 cents more per gallon at Costco. why? Just habit I guess.
Consider the average driver will spend approximately $2000 more for premium over 10 years. However for a new RX they will loose approximately $20k in depreciation over 3 years.
If you are one to factor in cost trying to save money, look at the big picture. I don’t think $15-$20 per month is worth agonizing over. Especially since we are talking about $60k+ vehicles.
#71
Due to higher elevation causing lower compression, lower octane can be safely used in naturally aspirated engines at high elevations. This is not the case for turbocharged engines such as with the RX350 and RX500h. Also, if one is driving at high elevations, but intending to return to lower elevations with the same fuel, one needs to put the correct octane in.
#73
I love my 2024 RX 350h Luxury!
#74
I have been using 87 octane for 18 months and the engine does not knock or ping. I usually get 35-40 MPG unless its extremely cold outside. I have never compared the 91-93 octane to the 87 but even if you got 1-2 MPG higher, the higher price would more than negate the extra miles gained.
GFerg
04-24-06 09:37 PM
