Is300 shifting problem? HELP! HELP!
Originally posted by rominl
boy glen, you have your GS for so long already and you never know about that feature? you people you never read the manual
and yes and no to what you said. no it does not DROP to 1st. when you are at the light, it's ALWAYS at 1st, even if you don't gun it. it just starts in 1st that's all. and then 2nd, and then you shift to 3rd, etc... remember, the numeber NEVER EVER means the gear you are in. it means the highest gear you can go..... makes sense now?
and yes when the car is cold, you can NOT go to 1st. that could be one reason. also when the car is in snow mode it will start in 2nd too i believe
exclusive matchup
Originally posted by kokonutjc
Hey thanks for all the replies guys....That just helps me understnad more and less frustrated. hahahaha. Again thanks ! ! !
Reply to IS300 shifting problem
Also, on the 2001 IS300 E-shift, you will also find a couple of other quirks.....at cold temperatures, 3-4 shifting is delayed for a couple of blocks, and 4-5 is delayed in both Manual and auto modes until the engine temperature reaches 140 degrees. The 4-5 delay is emissons-related to warm the engine and catalyst sooner. Why the short 3-4 delay? Not sure...maybe also temperature and emissions-related. 3rd gear is pretty short in the IS300 and this puts a lot of RPM on a cold engine.
Don't know if this helps ........... my mother-in-law has an Acura 3.2TL. Hers will automatically shift into a higher gear when it reaches a certain rpm. The rpms are lower when in a lower gear & shifts quicker.
Lexus Connoisseur
exclusive matchup
Originally posted by flipside909
Yeah, the Honda/Acura Sport Shift system is designed to automatically upshift when it reaches redline or a certain RPM. The Lexus E-Shift system just bounces off the rev limiter and WILL NOT upshift to the next gear.
Yeah. 04 LS430's 6spd is beautiful. I'll ask Liz to take me for a spin tomorrow.
As for the shifting...my 2004 will hit redline in M-Mode in 2 (start in 1st and end up in 2nd). The way E-shift was programmed for the IS, you only have control of upshift/downshift to and from 2nd, 3rd, 4th and 5th from 2001 to present. You cannot go into 1st because the computer wont allow it....UNLESS you manual row the gears into L through the shift gate. The reason why Lexus only allowed only as low as 2 was to keep people from blowing their motors and tranny so to speak. Why they didn't allow it to be shifted into 1st...but allow all the other Lexus models with E-shift can be shifted into first beats me. 1st is a very short gear to be of any use at all anyways. But yes, in M-Mode 2 of eshift...your gear will start in 1st and go up to 2nd only as Rominl and everyone else explained. The manual explains this too.
Flip, you say that question beats you. I think part of the reason why the E-shift does not allow 2-1 downshifts, can be explained by the difference in final-drive gearing between the IS300 and more sedate Lexus products like the ES and LS. The IS, being primarily a sport sedan, has noticeably shorter gearing than other Lexus products, so an abrupt downshift into 1st at anything except very low speeds would give the drivetrain quite a jolt and, as you suggest, cause major damage. Yes, you can still do it with the lever, but most IS300's are not as likely to be driven as hard with the lever as with the buttons.
Now what has ME beat.....why doesn't the shift lever itself allow a 5-4 downshift?.......you can only go from 5-M-3. It by-passes 4th....you have to hit "M" and press the DOWN button to get 4th. Lexus has never really explained that one. You got any idea?
exclusive matchup
No.......in the E-shift, fourth is not a significant overdrive; it is either a direct 1:1 or very close to it. 5th is a traditional overdrive....but still a little shorter than, say, the ES300's 5th, due to the shorter final drive in the IS300. I think that the engineers who designed the shift lever probably figured that people who wanted (or needed) to downshift from 5th to 4th would probably want the buttons anyway. The buttons are easier to use if you are going in a straight line, but the lever is more convienent in turns.
It's a little odd, but certainly nothing that I'd dump the car for....and you get used to it after a few days.
exclusive matchup
Re: Reply
Lexus Connoisseur
Hypothetically, any gear above 3rd gear is an OVERDRIVE gear. Since 3 is the standard drive gear, any gear past that is OVER drive.
