Anyone put a Altezza cluster in IS300?
Has anyone put a Altezza cluster in a US spec IS300? I wanted to put one in my car but don't know if it's plug n play or is there modification to make it work? Does it have to be the same year IS? I heard that the 2001 are different then the 2002+ cluster and are not interchangable. What are the differences is the two clusters? Thanks in advance for any help.
I don't know this for a fact, but my guess is that some of the fuel gauge markings also be different to account for liters rather than gallons.
Originally posted by mmarshall
If you're talking about the dash / instrument cluster, the main differences between the two would probably be that the Altezza / IS200 speedometer would be accentuated more toward KPH's rather than MPH, the odometer more toward kilometers than miles, and the cluster may or may not come with an airbag warning light and hookup.....many countries overseas where the Altezza is sold don't require airbags.
Lexus Connoisseur
Originally posted by rominl
i believe the altezza (or trd??) cluster, the center circle is rpm instead of your speed. that's totally racing oriented
the gauge cluster sounds cool, any pics of it?
edit: nm, found pics of it myself
Originally posted by flipside909
That is correct. The center guage is your Tach instead of your Speedo and the speedo calibrated in km/h obviously is located where our Tach is.
hey you never know when it's coming in handy ;_
Originally posted by Lexan
I have. Everything works except the night time lights....which im currently trying to figure out how to do it.
When you put the car in reverse, it goes ........beeep beeep beeep.
it was plug an play but
issues:
1. it reads KPH not MPH
2. tach is off (redline is at 8500)
3. night lights work but can't dim them.
Lexus Connoisseur
issues:
issues:
concavo
11-20-12 05:35 PM
