I love this car
Originally posted by amy011079
well i have an 03 IS and I have 41k miles on it. what does THAT tell you.
Originally posted by mmarshall
It tells us you're going to have some high-mileage depreciation on it. But hey...if you enjoy driving it....and the IS is a great car.....I sure enjoy driving mine.........what the heck? It's only money.
Lexus Connoisseur
Originally posted by 2jz_whoa
Does anyone else ever just kind of drive their car for no reason.
Lexus Connoisseur
You guys are nuts im like nervous because i've put 900 miles in like two weeks. But i have taken a road trip to gainsville and of course you are going to be more ready to drive when you just got the car. I would like to keep it to 12,000 miles a year if possible it will probably end up at like 15 though.
I averaged about 40K miles a year.
If you all are that concerned about driving a lot of miles and saving gas, then try bumping the tire pressure up a little...no more than 2 lbs....to 35 PSI; keep the transmission switch in the NORMAL mode, not the POWER mode; use the A/C compressor as little as possible, try to combine trips so that the engine stays hot and you are not warming it up constantly (which uses a lot of gas) , clean all the unnecessary stuff out of the trunk so you're not dragging extra weight around, and of course, use the old-fashioned methods.....easy on both the gas and the brake pedal. The ride will be a little stiffer, you may not have as much driving fun, but this should be good for about 3-4 extra miles per gallon.....EXPENSIVE gallons out there in CA, from what we're seeing back East here.
In the D.C. area here unleaded 93 octane premium is going for $1.85 to $2.00 a gallon depending on the station. Out there in CA we see signs on the news here showing $2.30-$2.40.
Lexus Connoisseur
