Fuel Cut Off Manual IS Question and a Top End Run with WRX.
Originally posted by flipside909
I think you're forgetting a big factor here. The 2ZZ-GE was designed by Yamaha and was allowed to be a high revving motor to reach its powerband. The 2JZ-GE on the other hand wasn't designed to be buried past it's redline. You have totally disregarded the idea that the I6 in your IS is not a torqueless motor that needs variable lift to gain power. The 2JZ wasn't designed, engineered or built to rev high. Period. The IS is in a different league than the Celica is. Drive it more responsibly or you'll be asking for a rebuild or engine swap sooner than you know it.
IS' rev limiter is ignition controlled. The speed limiter is fuel cut.
