My custom dash mounted wideband display
When I was trying to decide on a wideband A/F meter setup for my car, I knew I wanted some kind of subtle output display. Therefore, I didn't want a large gauge-type display and preferred the digital displays because I want to maintain a "stock" appearance. I ended up purchasing the Zeitronix Zt-2 wideband system because it's digital display and ability to also support boost and EGT sensors.
I had everything installed a few weeks ago, and just put the Zeitronix digital display unit in the open area under the radio:
The shop that did the install gave me the Apex'i SAFC stand as a temporary mount to hold the display up while driving.
However, I always wanted something that looked a little cleaner and didn't require positioning of the display each time I got in the car. I was always planning on mounting the display somewhere and finally decided on the dash area where the TRAC button is located. So over the weekend I opened up the Zeitroninx digital display, modified the dash piece, mounted the display inside the dash piece, and put it all back together. I'm pretty pleased with the results.
![](https://www.clublexus.com/gallery/data/500/20932IMG_2876-med.jpg)
![](https://www.clublexus.com/gallery/data/500/20932IMG_2887-med.jpg)
The best part is, the only irreversable change is the modified dash piece. I can put everything else back to it's original state.
![](https://www.clublexus.com/gallery/data/500/20932IMG_2801-med.jpg)
![](https://www.clublexus.com/gallery/data/500/20932IMG_2875-med.jpg)
![](https://www.clublexus.com/gallery/data/500/20932IMG_2878-med.jpg)
Thanks guys.
Solo, the display isn't too low for me. It's actually pretty good for my seating position. If I were shorter or sat closer to the steering wheel, then it may be a little difficult to see. Also, the only other place I was considering to put the digital display was in the coin holder location, but the steering wheel blocks the view. I didn't want to mount it above the center console because I have my JDM dash tray there.
And the car is running better now. It's running a little rich, but I'd prefer that over being lean. I wasn't successful in tuning a couple weeks ago because I couldn't get my laptop to talk to my additional injector controller. As a result, it was a wasted visit to Dyno Labs, and I could've attended the meet at Folsom Lake instead.
So now I'm getting the remaining E-Manage components installed (injector harness and pressure sensor with harness). That way I can just drop the Split Second AIC1 (additional injector controller) and tune the car with just the E-Manage. When I get the car running well, I'll have to post about my car since I'm still fairly new here, even though I've met a couple key NorCal people already.
Lexus Connoisseur
That looks simply amazing. Just imagine if the rest of our dash lighting was in that color motif!
Thanks for the comments.
flipside, I agree, it would be pretty cool if everything was color matched. I thought about just putting on a red/orange tinted piece of plastic/acrylic instead of the clear piece I have on there now. I just don't feel like re-cutting that piece. I got lucky and the first one just fit really well, so I didn't want to mess with it anymore.
I also don't want to go through the trouble of swapping out all the interior LEDs, etc. (Not yet)
Not yet. I haven't had a chance to take a video. It's hard to drive at the same time and hold it steady.
I do have a video from Zeitronix of it running in another car. I'll try to take a short vid with someone else holding the camera. I'll need someone to host it though.
mjessup
ES - 5th Gen (2007-2012)
09-03-17 01:19 PM
passnu2
10-16-08 04:29 PM
