remove yellow from is300 foglight.
#31
Originally posted by rominl
i am curious why it would decrease light output? if you sand it rough, then go to 180, 220, and eventually wet sand with 2000 you get pretty much a clear lens?
#33
#35
just sanded the lens.Your right, on the len ,it's clear,they spray the lens with some transparent yellow paint on the flat side of the lens.my bad
#36
wow, this is a great guide. i wish i had the guts to bake the fixtures though. can you elaborate on that procedure?
so i guess after your final test, paint thinner will work just like sanding? i do like that RX light swap though. seems easy and painless.
i like to do this except that i would hate to mess up anything having to bake and then reseal...how do you reseal anyway?
thanks.
thanks.
#40
thanks.
thanks.
#41
Originally posted by lexus4jess2
you can use a heat gun to remove the lens as well.
if you don't wat to put it in the oven.
#42
thanks man for the helpful info. still debating if i want to try this out myself. maybe when i move out to SOCAL, i can seek your expert help in this area in person.
#43
it's a nice mod if you wanna have matching headlights color, you should do it. me myself i love the yellow fogs which tells it's a lexus, that's why i am keeping them
as for functionality, you think yellow outperforms white in foggy conditions? or maybe not much difference.
#44
yeah, i like the yellow fogs. i don't turn on my fogs unless it's really foggy or raining. but i do also like the white. i can't decide.
in terms of foggy occasion, yellow DEFINITELY works better than white. the idea under foggy situation is that you want to have some soft light penetrating the fogs. yellow is a lot softer than white light, so that's why. putting white (specially if you change the bulb to superwhite as well) it's not going to help in foggy situation
#45
oh my fogs on both gs4 and is3 are always on whenever headlights are on
i just love them too much, hehe...
in my first bmw, i used to keep the fogs on all the time, but i found out that they kinda burn out too fast. after that car, i just kept the fogs off on the cars and used them when necessary. in doing so kept the bulbs lasting for a really long time. i think i have gotten lazy, not that it's a big deal or something to replace the fog bulbs.
