Roof Problem help plz....
does anyone have a problem with the roof? my roof have some kind of rumbling everytime i go over a speed bump or a dip...i think it might be a loose wire up there and i took it down lexus and they say they can't find the rumbling noise...does anyone else have this problem? or do u know wat can be wrong?
Lexus Connoisseur
Rumbling? like rominl mentioned...you should open up the roof to see if the rubber gasket hasn't seated properly from open/closing. alot of moonroof noise is attributed from that gasket rubbing onto the painted surfaces of the sheetmetal edges.
You may have someting like a rock rolling around in the little trays that catch water in the front and rear of the sunroof.
VanIS350
05-11-06 08:54 AM
