2001 is300 OEM navigation....
i have a 2001 lexus is300...its fully loaded but no navigation since it was not offered on 2001 models. im looking to add a gps system to it and im trying to get the factory gps system. i can get the screen, buttons(next to shifter) and brain(the one in the trunk) what else would i need. and will it even work in the 2001
here you go
http://www.is300.net/forums/showthread.php?t=154218
http://www.is300.net/forums/showthre...Installing+NAV
You should find everything you need in those 2 threads
Ali I have done the GS retrofit.....hmmmm... maybe I should do one for the iS too
Do you have all of the plugs that go to all of the devices? That is the one piece you must have.....
i actually want to do a retrofit b/c the IS has nav controls near the cupholder and its integrated into the factory sound... all aftermarkets need another speaker just for itself.
im trying to get the oem nav system out of an 02 is300...i like the stock look and don't want to change it. if i can get a good deal on it will it work in the 01 is300. thank you.
Lexotic Concepts
2001 IS300 models are not "pre-wired " for the Lexus Navigation System. It will be a splicing nightmare and you WILL need a 2001 AND 2002 factory service manual to identify each wire for a successful install.
2001 and 2002 have different wiring harness.
I also like the stock look but why go thru the hassle for something trivial. I'e grown to like my touchscreen setup in the stock NAVI location. Its better than fumbling with that goofy joystick.
I turned to the darkside of aftermarket.
One more thing you need to be aware of stock nav is that you can't do nothing while driving. You have to stop and then it'll let you punch in new address. I use the OEM nav housing with Pioneer system and it look so stock, most people wouldn't even know.
Lexotic Concepts
here you go
I also am planning on adding a sterio system I purchased and pieced together. Sony XES T1, P1, C and so on etc...... All together I'm looking at KILLER sound. Can't wait!
