IS300 LED mood light installed
#31
EV ftw!!!
Originally Posted by TRD-bB
my next mod is LED on the center overhead console, the map light / sunroof switch area. like the LS in the pic
but I still can't figure out a way to mount the LEDs without getting blinded by them.
I want some light shining down, but I don't want to see the light source...... any suggestions?
#32
O.L.T. congrats on your new SC4
#34
The Green Grundel
That looks awesome! This is for sure going to be my first mod.
How many LED's are under each of the 2 footwells (or whatever its called) Is it just one or is there more?
Also, would these bulbs work better? They are inverted to spread the light out more evenly.
#35
Do you know the mcd rating for the LEDs that you used? Did you use a resistor on every LED that you installed?
Could you make a simple wiring diagram for those of us who are not electrically inclined?
Looks great by the way.
#36
I use one LED per footwell.
I bought some Razo wide angle spot light from a local car acessory shop for about $10
hard wired them to the glove box light, which only comes on when your head lights are on
http://www.autohalogen.com/interior/razo_spotlight.htm
#37
These are the LEDs that I use.....I know, it's $3.29 each if you have to pay for them....which I don't
http://www.radioshack.com/product.as...5Fid=276%2D311
Yes, I used a resistor on every single LED.
I'll try and make up a diagram.....but I'm not too electrically inclined as well
everything I did is by trial and error
#38
Originally Posted by amy011079
yes that's always been something i would like to do. i love the way my sis's 325 looks at night. the new IS will probably come with those. i know the new GS does but what is so cool is it's a white color.
still debating if I should take the plunge
#39
Originally Posted by lexusondubs
wow man i really like the foot wells !!! id like to see it with the white led's !!!
#40
Thanks
http://www.superbrightleds.com/
I have ordered from them before (because I use LEDs in RC applications) and have had no trouble. In addition, they are cheaper and the specs on the LEDs are a lot better. They are a lot brighter and still retain the same viewing angle (depending on which one you choose).
noeldavid
RX - 4th Gen (2016-2022)
196
03-07-23 08:08 PM
