IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
MY IS300 is SHIFTING WIERD ! HELP!!!
Old 06-12-01, 05:26 PM
dpatterson069
dpatterson069's Avatar
HELP ME PLEASE!!!
when i drive my is300 w/ trac off it seems to shift fine from 0 to 20 with normal acceleration , BUT WHEN it shifts to about 40. there is a HUGE LONG pause!! ITS LIKE THE CAR CANT FIND THE 3rd GEAR or something!!! HELP ME PLEASE!!!
im not totally sure what this problem is, though i think it is do to the TRAC/ECU problem... but i would like to know if anyone else has encountered this problem and specifically what it is....
PLEASE HELP ME~!!! IM FREAKING OUT!!!
thanks
david
Old 06-12-01, 06:05 PM
Marley
Marley's Avatar
I had that problem. When accelerating hard the car sifted into third really hard. When the ECU fix came out they reprogrammed my ECU and Gave me a new trac unit. Check your VIN. When I got the car back everything was OK. The car rides perfect now.
Old 06-12-01, 08:27 PM
dpatterson069
yea,
i heard and got all the info on this back when it wasnt a problem for me..
but i also heard from a well informed lexus employee that by fixing the trac/ ecu problem., it can slow down ur IS300
so i am hesitant to do so...
david
Old 06-28-01, 06:01 PM
Sooner
Sooner's Avatar
Default trac ecu
you guys quit whining if you dont like the way it works have it fixed if it works fine shut the hell up.it wont slow your car down and if it does a little you wont notice it so all you guys need to quit your bellyachin!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
Old 06-28-01, 08:04 PM
dpatterson069
you guys quit whining if you dont like the way it works have it fixed if it works fine shut the hell up.it wont slow your car down and if it does a little you wont notice it so all you guys need to quit your bellyachin!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11: mad:
sooner,
i think my last post was quite a while ago...so why dont u look next time at the date that the "whining " took place..OK??
thanks
farajfad
Performance
19
01-31-22 03:41 PM
ISash300
16
09-25-10 09:12 PM
kokonutjc
25
01-25-04 07:41 PM
EvoIS300
09-26-02 04:50 AM
dragion
07-25-01 08:52 PM
Quick Reply: MY IS300 is SHIFTING WIERD ! HELP!!!
