IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
What happens if you take the projector out of the fog light?
Old 02-21-06, 08:16 PM
kgh31386
kgh31386's Avatar
Default What happens if you take the projector out of the fog light?
Will this cause a God forsaken glare? or since the lights are really aimed down at the ground, will it not really cause much difference besides a wider spread on the ground? Because I really want white light coming out of my IS300 fogs. If it is absoultely necessary to have a lense in there, anyone have a clear one that'll fit or know what kind will fit so I can go buy them? thanks guys
Old 02-21-06, 11:01 PM
rominl
exclusive matchup
rominl's Avatar
?! just take out the lens and use a sand paper to sand away the yellow layer on the surface. there you go clear fogs
Old 02-22-06, 09:34 AM
kgh31386
kgh31386's Avatar
ahhhh, so is the lens kinda this shape (I , like the front side is curved. and the back side is flat? sorta like a semi-circle or slice off of a circle?
Old 02-22-06, 01:32 PM
rominl
exclusive matchup
rominl's Avatar
i believe so. i never took it apart before but i have seen people did it and showed pics. so it's all from memory. i remember they said they took out the lens, sand it, and it became clear lens
Old 02-22-06, 01:58 PM
Ms DaZe
Ms DaZe's Avatar
if you take out the lens, its like taking out the projector.
the light from the 9006 or H3 bulb wont portray as nicely as it would with a lens.
___
just my 2 cents.
2jTonio
06-06-15 05:11 PM
badboylx04
GS - 1st Gen (1993-1997)
11-10-12 07:01 PM
O1GS43O
05-03-10 12:34 PM
SC3coupe
07-20-07 11:27 AM
ripe911
Lighting
08-19-03 12:59 PM
Quick Reply: What happens if you take the projector out of the fog light?
