removing map light cluster near rear view mirror
Hi All, Is it true that the map light cluster can be removed by simply muscling it out by pulling it straight down. No screws or clips to remove?.
The light isn't working but other lights on the same circuit are working so I'm assuming that either the bulb is bad or there is a problem with the switch or connector.
Any wisdom/experience would be appreciated. Regards.......
xtwister16
RX - 1st Gen (1999-2003)
28
12-13-23 09:27 AM
