Need help with check engine light
I'm getting two codes which are PO141 and PO715. The first one says its a sensor heater circuit malfunction or something like that and the other says input turbine speed sensor (A) circuit malfunction. Any encountered these codes before any suggestions will be appreciated.
i concur ... probably O2 sensors ... i took mine to my tuner shop when my engine light came on and the guys said it was just O2 sensor 1 and 2 and that it was no big deal i could wait on replacing them if i wanted ... so my light is still on :P
and yes im getting it fixed before the end of the month and no im not neglecting my car
Mine CEL came on recently, it was showing a bad 02. Bank2, sensor2. Lexus dealer wanted right at $400 to replace it. I ordered it from ******************.com for $118. Took me all of 45 minutes to change it out. No more CEL and my gas mileage is MUCH better.
agit8or, I did the same thing with sensor 1...however, my check engine light just came back on again? Has your light come back on since you replaced your sensor?
BilluAwan
11-16-08 03:54 PM
