Auto tranny questions
I just recently purchased a 2002 IS 300 and for some reason in manual mode it won't let me shift down into 1st, it just beeps at me even when im at a dead stop. Does anyone know why this is?
yup
Like Amy just said
E-shifts only goes down to 2, there is a main reason why toyota designed the car that way, i forgot what it was. i think something to do with safety for engine and driver. someone correct me if im wrong.
Its not and Audi its a Lexus
Naw, you just launch it in e-shift. The car is in 1st gear even though it says 2nd. You cannot manually shift the car until after the car shifts itself from 1st to 2nd. Once the car is in second then you are free to shift.
if u want to decide when u shift into 2nd [from 1st] ... you can start in "L" ... u can only shift into L when ur @ a stop tho ... and i'm not sure if that's bad for the car or not ... i've only done it a couple times when i rly needed to win a race off the light
You can also put it into PWR mode to get the best rpm's out of 1st gear when in M-mode. I always turn off traction control too. Pisses me off when I jump on it and the car slows itself down because it feels the wheels slipping. That always seems to happen when I NEED the power to get out of the way.
Lextrician
07-08-14 07:07 AM
