Where is engine drain plug? How many?
There's only one block drain near the right rear of the block. Since this is a in-line 6, only one drain is needed since all the cylinders are in a common bank, if you will. Your LS has two because the "V" engine has two banks of cylinders.
I found it easier to get at if you remove the fresh air intake tube (just two clamps) temporarily, which allows for a bit more swing on the wrench and much better visibility.
