Can you say, "YOU ARE TOAST!!!"
I just had to post this up for you guys to see! This ************* car is the ******!!! :eek: :eek: :eek:
Specifications
Year 2002 Powertrain Layout Mid Engine / 4WD
Make Bugatti Base Price est $800 000 USD
Model 16/4 Veyron Production Not Available
Engine & Transmission Body / Chassis
Configuration Quad Turbo W16 Weight Not Available
Valvetrain DOHC 4 Valves / Cyl w/VVT Length 4466 mm / 175.8 in
Displacement 7993 cc / 487.8 cu in Width 1998 mm / 78.7 in
Power 746.5 kw / 1001.1 bhp @ 6000 rpm Height 1206 mm / 47.5 in
Torque 1250 nm / 922.0 ft lbs @ 2200-5500 rpm Wheelbase 2700 mm / 106.3 in
Bhp / Liter 125.25 bhp Front Track F 1723 mm / 67.8 in
Bore 86 mm / 3.39 in Rear Track R 1632 mm / 64.3 in
Stroke 86 mm / 3.39 in Steering Not Available
Redline Not Available Body / Frame Not Available
Gear Type 7-Speed Front Brakes Not Available
1st Gear Ratio Not Available Front Brake Size Not Available
2nd Gear Ratio Not Available Rear Brakes Not Available
3rd Gear Ratio Not Available Rear Brake Size Not Available
4th Gear Ratio Not Available Front Wheels F 52 x 23.5 cm / 20.5 x 9.3 in
5th Gear Ratio Not Available Rear Wheels R 54 x 32.5 cm / 21.3 x 12.8 in
6th Gear Ratio Not Available Front Tires PAX 245/690R520
Final Drive Ratio Not Available Rear Tires PAX335/710R540
Performance
Top Speed 406 kph / 252.3 mph 0 - 60 mph est 3.0 seconds
Specifications
Performance
Originally posted by fairuza11
DAYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYAAAAAMMMMMMMMMMMMM!!!!!!
Take a look at the engine compartment!!! Oh by the way, it's sitting behind Your Head!!! :eek: :eek: :eek:
it doesn't hold a candle to the mclaren2 though.
i forget the exact specs, but i think it is 1600hp, awd and 2000 pounds or some crazyness, it also runs 7's in the quarter, bone stock.
well, the way i look at it is, if you are going to **** away $800,000, why not **** away the extra $400,000 and treat yourself to the mclaren?
if it was me, i'd mod my IS, and mod a supra.
Originally posted by TXSTYLE
I think I'd spend that extra couple of hundred thousand dollars more for the McLaren and um, hmmm, add a few more extra garages for a couple of "heavily modified GS & SC" how about both of them custom painted, w/ custom interior lambskin, both super-charged, w/ custom ground effects, and riding on 22's!!! Hey I said "heavily modified"!!! :eek: :eek: :eek:
