IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Major help on installing the S-AFC!!
Old 11-05-01, 04:17 PM
RysBURNER
RysBURNER's Avatar
Default Major help on installing the S-AFC!!
i just bought the S-AFC and i dont have the wiring diagrams for the 01' IS300 so i really need help on installing this unit. Any help that anyone can provide for me will b most helpful
Old 11-05-01, 06:37 PM
EmoDragRacer
EmoDragRacer's Avatar
ask IS300GTE he has diagrams for our cars..
Old 11-05-01, 07:01 PM
RysBURNER
RysBURNER's Avatar
thanx a lot fairuza11!
Old 11-05-01, 07:26 PM
gte
gte's Avatar
i emailed both the 01 and 02 to you, as i only saw that you needed the diagrams (with no specific year listed in your private message).
fairuza, whoever owns this site, if they want to have a faq or some type of data base to have stuff like that, tell them to let me know, i also have the alignment specs on file for the IS3 that i could give them too.
Old 11-05-01, 10:29 PM
VVTIS
VVTIS's Avatar
GTE, can you email me the 02 specs? Thanks.
Chris
Old 11-06-01, 06:43 AM
gte
gte's Avatar
auto or stick? and did you message me also, someone did that, if not, post your email here, so that i can email them to you.
Old 11-06-01, 05:14 PM
VVTIS
VVTIS's Avatar
5 speed, it is Jesta_c@mail.utexas.edu How much of a difference is there between the two? Thanks man.
Old 11-06-01, 07:19 PM
gte
gte's Avatar
done, there is a HUGE difference between the autos and sticks, they wires and connectors are not even close to being the same, nothing can be referrenced to the stick from the auto, kinda sucked for a while, didn't make things very easy to figure out, i'll tell you that.
-gte
Old 11-06-01, 07:37 PM
STKSKI
STKSKI's Avatar
Ok guys i got a problem now. I wired in my SAFC about a month ago and it worked great until 1 week ago when i went to get my cd changer fixed at lexus. When i got the car back my check engine light was on and the afc wasnt turing on. I tried resetting the ECU but the afc still wouldnt turn on. I checked my battery to make sure everything was tight and it was and finally i checked my connections. I couldnt find anything wrong with it. I am now lost and cant figure this out! Help please, any ideas.
Old 11-06-01, 09:10 PM
RysBURNER
RysBURNER's Avatar
i installed my s-afc and it worked fine until i tried starting my car again. the car wuz having trouble starting up. then i tried starting it up again and then it did but died 3 sec. later. i checked everything. now wen i start the engine it starts but still having that difficuty starting and my check engine light is on and my trac control light keeps on flickering. i just unpluged the Air Flow wire so i could just drive home. if anybody noes whats wrong pleez help!!
Old 11-07-01, 07:12 AM
gte
gte's Avatar
it sounds like both of yours need more stable power or ground sources.
Old 11-07-01, 09:42 AM
RysBURNER
RysBURNER's Avatar
Talking
I FIXED IT!!! i just put the afc on stock settings and BWAAM it worked well ima go and c if it really does work. ima drive it around 4 a bit so if i dont post n e thing by the end of this day then itz all good
Old 11-07-01, 12:10 PM
STKSKI
STKSKI's Avatar
My pos. side to my battery was loose but when i tightened it, still no AFC. I dont know why it wouldnt power, everything is connected up and it just stoped working after lexus touched it. I dont know what to do, this sux
Old 11-07-01, 01:08 PM
RysBURNER
RysBURNER's Avatar
Where u getting the trac/ecu replacement thing done wen this happened?
Old 11-07-01, 06:27 PM
STKSKI
STKSKI's Avatar
Nope, all they did was replace my jammed cd player...
Quick Reply: Major help on installing the S-AFC!!
