Need Help Locate Vss Wire Harness
http://my.is/forums/mobiletronics/27...-wire-pic.html
If you are too lazy to click on the link:
"If you go the drivers side kickpanel.
Above it there is a black plastic control module. It's mounted vertically. (Near the large grommet in the firewall)
It has 4 white plugs in it.
The 2nd plug from the bottom has a VSS wire running to it.
It's pictured below.
Red/Yellow is the wire color."
Quoted SophieSleeps
Quoted SophieSleeps
ALLWiTE2JZ
02-16-10 08:24 AM
