IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Offset question for the IS300 experts
Old 04-06-07, 01:40 AM
miss_IS300
miss_IS300's Avatar
Originally Posted by JCE102JZGE
my car will only be dropped an inch. No wheel gap? wow did you do any fender mods? how about some pictures... id like to see what it looks like.
I have a 225 in the front instead of a 235 now but I had to have the fenders rolled in the front and the rear. The fender liner in the front also had to be cut so that the wheel wouldn't rub against it as much.
This was when I had 235's on the front and 245's in the rear. You can see that if I had kept the 235's I would've been forced to raise the car up to prevent the wheel from destroying the fender.
This is my current set up. I'm going to be picking up fenders or possibly flares sometime in the future because I want to go with a much much more aggressive offset all around.
No wheel gap.
If you check out this link you'll find that we test fit a set of 18x9 and 18x10 Work VS-KF's on Solo's car which has fender flares. The wheels had a +13 offset all around but Solo has a 8mm spacer in the front so it is essentially a +5 offset. There's hope for us 1st Gen IS's.
http://sr1.clublexus.com/forums/showthread.php?t=274205
Old 04-06-07, 04:46 AM
JCE102JZGE
JCE102JZGE's Avatar
good god thats insane... freakin sick! i gotta save up more cash then. screw shaving fenders im going flares now.. haha
your car is very impressive btw miss_IS300
Old 04-08-07, 05:28 AM
DR-JEKL
DR-JEKL's Avatar
I am looking at importing a set of Weds Bellona from Japan
They are 19 x 8.5 with a 42+ offset on the front and 19 x 9 with a +38 offset on the rear
Will I get away with these wheels with the car lowered approx 2" on Tein CS coilovers?
Cheers
umvagia0
10-18-17 07:13 PM
markgs4
Wheels, Tires & Brakes Forum
06-14-06 10:48 PM
evolon5150
02-04-04 07:26 PM
TopSCecreT
11-10-03 08:32 PM
Hornda
07-23-02 02:28 PM
Quick Reply: Offset question for the IS300 experts
