IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Apexi S-AFC to use with IS300??
Old 12-16-01, 10:15 AM
Sheliz
Sheliz's Avatar
Default Apexi S-AFC to use with IS300??
Does anyone know if there is a specific apexi afc unit that is compatible with the IS300? I want to get the Apexi S-AFC unit to go withmy AEM intake because I heard some people had problems with the intake, this eliminates the engine light coming on??? Any info would be appreciated.. thanks!!
Old 12-16-01, 01:37 PM
Sheliz
Sheliz's Avatar
Another ?.... is it even necessary to use an air/fuel controller with an AEM intake, and does the Apexi S-AFC increase hp?
Old 12-17-01, 01:00 AM
dpatterson069
dpatterson069's Avatar
from what i know, the apexi afc will help similar to the SRT intake w/ the ecu unit it comes with..
the apexi will help gain the most power from the AEM intake.
alone, the intake will most likely give about 2-4rwhp, but with the aapexi, u could add another 4-6rwp on top of that..
u dont need an apexi to go with the aem intake. it works ( AEM) by itself..
the apexi will maximize the intake performance and power..
Old 12-17-01, 05:27 AM
Sheliz
Sheliz's Avatar
Smile
Thank you
Old 12-22-01, 12:45 AM
RacingAristo
Guest
Posts: n/a
2nd gen. S-AFC should work fine with your IS. I've seen it on several IS300. In order to eliminate the engine check light, first you have to take your car to the dealer and find out what the problem is.
You do need a fuel computer to find tune the fuel/air ratio. S-AFC provides 8 points (I think it's 8, not 100% sure) where you can manipulate those settings.
jmull3r
Performance
07-21-17 01:31 AM
roxster
Performance
12
07-11-05 10:10 PM
freshfish
Performance
12-06-03 11:26 PM
Papadop88
Performance
05-10-02 03:49 PM
dpatterson069
Performance
12-05-01 05:56 PM
Quick Reply: Apexi S-AFC to use with IS300??
