Parking lights failure. . .
I installed my demon eyes kit on is. i wired it on to the parking lights and it worked fine, but then the parking lights stoped working, aswell as the deamon eyes. i checked the fuses and they were good, it still didnt work, so i replaced them but im still having that problem. i also go new light bulbs but it wont work. lastly i removed the deamon eyes from the connetion, but sill the lights wont work. . . Does anyone have any idea what might be wrong??
If i were you i would get a test light and check if your even getting power to that circuit. If your fuse is ok, and your lights dont't work changes are you not getting power to the circuit. I had the same problem with my angels eyes, but mine had a fault converter for the angle eyes cause my parking lights not to work either. if you find that you circuit is not getting current, i would start chasing done the power wire.
Good luck
Good luck
