IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Tuning an Apexi s-afc ??????
Old 12-21-01 | 05:26 PM
Sheliz's Avatar
Sheliz
Question Tuning an Apexi s-afc ??????
Just got an AEM intake and Apexi s-afc installed....
If anyone knows how to tune the afc please help, is there an optimal setting I should use or what?? It's kinda confusing so any help would be appreciated, thanks
Old 12-22-01 | 01:31 AM
RacingAristo
Guest
Posts: n/a
No, there isn't. You have to take it to a shop where they have the dynojet so they can find tune your car. I got a quote for $200.
Old 12-22-01 | 09:37 AM
Sheliz's Avatar
Sheliz
what kind of places have a dynojet? i think for now I am going to just use the factory settings on the car... i was reading the afc manual and on every page there was something like "failure to do this could cause serious engine damage" or "could cause accidents" yikes.
Old 01-05-02 | 02:31 AM
lextec's Avatar
lextec
Exclamation
Sheliz, RacingAristo is right. You should get to the nearest or best dyno/tuning shop to properly set your AFC. You see, any component that alters your OE ignition timing & fuel settings has the capability of causing engine damage. It is up to the end user, the concumer, to select a competant & capable shop that will be able to effectively use a chassis dyno, be able to interpret its' results, and to exploit all of your AFC's parameters. Ask anyone that has invested time at the right tuning facility & they too will agree. Best of luck & happy motoring!
TLcoats
04-19-10 12:38 PM
turboant
01-23-10 04:26 PM
juice14
Performance
42
09-22-08 10:45 AM
SC3002JZ-T
Performance & Maintenance
04-08-06 03:54 PM
