Stickers on visor
Has anyone found a good way to remove the stickers on the visor? I hate those damn things, but I don't want to leave an imprint on the visor. Have any of you guys figured out how to get rid of them? There has to be a way.
try adhesive remover or gel bug and tar remover but be very careful - either may effect the plastic underneat and/or damage any surface it comes into contact with inside your car...makes those stickers not seem so bad now, huh?
damn you must have really wanted to get those stickers off... I think they use some insane adhesive... kinda reminds me of the tags on the bed matresses they dont want you to take off..
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
I removed the visor stickers on my moms 4Runner and all it takes is patience.
Her's what u do: get some adhesive remover and a hair dryer. If u can work on a sunny day (hotter the better but i know its winter right now) it would be best. Take the hair dryer and start moving it back and forth along the sicker until u can pull up a lil corner w/o leaving some sticky stuff. Then apply some adhesive remover, heat up that spot, and try to peel back a lil. Kepp doing this until the sticker comes off. Just follow the same procedure that u would if u were removing ur emblems (if u've done that before) the key to a successful removal is patience. Don't just rip off that sticker b/c then it WILL look ugly.
Just make sure that when u rheating the sticker up, not to get it too hot b/c it might effect the visor material/color in some way (kinda like when u remove emblems...when it gets to hot it could mess up ur paint) Hope this helps u in ur quest to removing the stickers
And remember: PATIENCE GRASSHOPPER
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Would you do the same thing with the sticker that is on the mirror side of the visor? I've tried taking a knife to the corner in an attempt to get an edge up to pull on but that proved to be fruitless.
i don't see why it wouldn't work. Don't ever use a knife, etc. though. This is a common mistake and is a fatal one. Eventhough u might not think u r scratching anything, if u look real close u will usually find a lil mark (if not more) from the sharp edge. (In ur case it would be a scratch in the mirror). Just take ur time and try what i said...its really not that hard. If ur still skeptical (sp?) i have used this method to debadge my SC300 (all emblems), debadged dads GS300 (just the GS3 b/c thats all he wanted done) and debadged moms 4Runner (all emblems and stickers). It has worked every time. IMO....I wouldn't pay to have someone do it b/c its nt worth paying someone $1 to do it plus, if they mess up they might not get u a new visor b/c u could be dealing w/ an a**hole.
