IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Speed Limiter
Old 01-13-02, 10:49 PM
solo
solo's Avatar
Question Speed Limiter
Are there a way to kill the speed limiter? I know the existing speed limiter is set at 143 mph. I know... I'm sure we all hit that acouple of times. Let me know.
solo
Old 01-14-02, 08:49 AM
EmoDragRacer
EmoDragRacer's Avatar
well with the stock ECU no, not that anyone has figured out... but with a standalone yes you can adjust your rev limiter..
Old 01-14-02, 11:44 AM
solo
solo's Avatar
Default in addition...
On the SupraTT you could pull a track fuse in the fuse box and the speed limiter was disabled. I know I friends that have hit 170mph land. Do we have a fuse to pull to go pass 143?
Old 01-14-02, 12:06 PM
munkeeboi
munkeeboi's Avatar
there is no ecu limiter on the IS. i beleive it IS Drag limited though. Please correct me if I'm wrong
Old 01-14-02, 02:25 PM
EmoDragRacer
the revlimiter is built into the ECU.. I dont know what you are talkin about man...
Old 01-14-02, 02:29 PM
Christobol
Christobol's Avatar
Have any of you guys with piggyback ECU's (A51, SRT) been able to pass the 143 barrier? One thing that I think is odd is that the stick and auto trannies are supposed to have the same top speed. They should be different because the auto is robbing 10-20 hp from the wheels.
Old 01-14-02, 02:33 PM
EmoDragRacer
I got my STOCK IS up too 148 once....
adding power does not make your TOP speed HIGHER.... that is gearing and rev limiter... you can have the addons SC or Turbo that will get you there quicker not make your TOP SPEED HIGHER!!!!
Old 01-15-02, 04:46 PM
solo
solo's Avatar
Default attention: fairuza11
how did u get ur stock IS up to 148 when the ecu cuts the fuel off at 143mhp?
-solo-
Old 01-15-02, 05:01 PM
Sentinel
Sentinel's Avatar
the 2002 i believe is limited to 130.
Old 01-15-02, 06:05 PM
EmoDragRacer
Cool
downhill!!!!! =)
Ltaboso
IS F (2008-2014)
05-26-15 02:32 AM
HeavycGS
02-21-14 03:49 PM
Hydro
Performance & Maintenance
02-11-11 10:49 AM
chris81964
01-27-11 08:57 AM
kaotiq
09-08-04 08:00 AM
Quick Reply: Speed Limiter
