Hid Fog Lights
Hid Fog Lights
2001 Is300, Has Anyone Installed HID'S In The Fog Lights, Would You Use 3500k Bulbs And Clear Lenses, Or Clear Bulbs With The Yellow Lenses. Or Yellow With Yellow, Which One Is Best. Thanks
Well that depends are you going to buy the JDM clear foglights, clear out the oem fog lights, or use the oem fogs as is? Because if you do any of the first 2 options then you can pretty much use whatever temp hid kit you want, but if you use the oem fogs with the yellow lens you have to use a 3000k hid kit or else your fogs will look green.
I just installed 3000k in my fogs about 3 days ago, and man talk about Looking JDM turns heads everywhere. Def recommend keeeping the yellow tinted fogs and throwing in some H.I.D, Only problem is they look brighter than the factory H.I.D headlights. So im planning on upgrading the bulbs to 6000K to even out the contrast.
Yup, upgrading to 6000k HID won't make it look brighter. It will make your headlight housing look whiter, but not necessarly brighter. You need to convert your headlights to projectors if you want to match your fog lights.
