IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Help my 6 disc changer is not working
Old 12-19-07, 03:26 PM
vee1909
vee1909's Avatar
Angry Help my 6 disc changer is not working
i have a 2001 is300 with the Stereo OEM 6 Disc CD Changer. I was wondering if there is some type of reset i can do. Currently the "disc" button is not responsive nor is the eject button. The load button seems to respond then it times out and switches to the radio. Note: the radio functions seems fine.
I would really...really like to retrieve my CD's!!!!
Old 12-19-07, 03:31 PM
mkiiina
mkiiina's Avatar
hey man, im betting you have an err 3 message.
its really not hard to take the stock HU out and pull the CDs out. theres a full write up over on MY.IS that you might want to check out in the mobilectronics section.
Old 12-19-07, 03:57 PM
vee1909
vee1909's Avatar
thanks mkiina, im new to this forum can you point me out to the "full write up over on MY.IS"? thanks
Old 12-19-07, 05:26 PM
Kyle Harty
Kyle Harty's Avatar
This seems to be a pretty common problem, at least this way you can get your cd's back.
http://my.is/forums/2997488-post18.html
Old 12-21-07, 02:19 PM
mkiiina
mkiiina's Avatar
/\ thats the one i used.
just a word to the wise. there should be 1 unplugged slot on the HU if you dont have the heated seats. blew a fuse figuring that out the hard way!
Old 12-22-07, 11:00 AM
2002GGPIS3
2002GGPIS3's Avatar
You can do the DIY, or if a lexus dealership is nearby most will get your CD out free of charge. This happaned to me and I was going to go to the dealership, but one day I turned the car on and the CD magically popped out. Good Luck!
Old 12-24-07, 08:43 AM
veka0904
veka0904's Avatar
I have a similar problem but mine says err 1 which means clean the disk and they're brand new..lexus wants $650 to replace it ...so i just hook up my ipod n its all good
Old 01-17-08, 04:52 PM
mrlexusmn
mrlexusmn's Avatar
If the rubber wheels that eject the cd slip on the ejection of the cd, the cd will get stuck in a state that is half deep in the slot and half in the rack. If your cd seems to be suck when you eject it, if you can grab another cd quick and just press in lightly into the slot, alot of times this will be enough to let the wheels grab again and eject the cd....otherwise if you are handy, you can remove the head unit and take it apart to help eject the cd. You need to be careful not to damage any of the carriers, or you will be f'd. If you are using burnt cd's, try and use ones that are not perfectly glass smooth, and this may solve all your problems.....
Old 01-18-08, 09:03 AM
crashzilla
crashzilla's Avatar
I always thought it was due to inserting a burned CD into the factory HU? For whatever reason they don't seem to like the flavor of those...
Old 01-18-08, 09:17 AM
jdmpwr07
jdmpwr07's Avatar
I switched out my stock 6 disk for an Alpine unit to play my Ipod. My stock stereo was fine but I've noticed that stock CD players (in my previous Solara and my mom's BMW) seem to go out quite easily.
Old 01-18-08, 11:30 AM
mrlexusmn
mrlexusmn's Avatar
I use 100% burnt discs. The player has no problem reading them. But if you use the wrong brand, ones with no texture on the cd face, you can get the slippage of the rubber wheels on insertion and ejection that causes the error.
i3leusky
04-06-15 02:09 PM
deedais
09-03-14 11:10 AM
ak22801
02-01-11 09:58 PM
gs300jh
12-06-10 08:28 PM
DrRick
10-13-02 02:10 PM
Quick Reply: Help my 6 disc changer is not working
