Can I put 235/45/17 on the rear wheels for a Sportcross
Hey guys
As the title states?
Can I go one size wider on the rear wheels of my SportCross. The width is 7.5 on those.
I had for few hours either 245 or 235 wide wheels on my SC before, and I remember the space between the tire and the suspension arm was minimal.
I was wondering if anyone is using this size tire on the rear wheels on a daily basis
Thank you
Thank you
thank you carwielde - I know wheels/tires from the IS 2nd generation fit the first generation IS. Those are wider tires on 18" and I figured they work b/c the 18" wheel moves the start of point of contact between the tire and the suspension parts higher. The suspension arm that I am taking about is angled so the taller wheel, allows you a wider tire.
I dont know if I just wrote makes sense. Just woke up - I'm traveling thru Italy
