removed cat and check engine light came on
i have an 02 is300,i removed the catalytic converter and my check engine light came on is there a way around it so i can get a sticker,i still have my o2 hooked up to the headers
emissions sticker or state inspection sticker? i dont know about the laws in mass, but in VA, a CEL does not prevent the car from passing state inspection. if you are looking for an emissions sticker, not having cats might put a damper on that.
either way, you will need o2 sensor simulators for the CEL. the vehicle monitors the cats to make sure they are working correctly. the vehicle basically thinks they are not working/knows they are missing, resulting in a CEL. you need the simulators to trick it into thinking they are there/working.
