i need some performance suggestions
i wonna make my car a little bit faster than it is i'm not looking for a turbo exactly but lil stuff to make it faster chips, exhaust, headers (exhaust and headers will be coming this winter) but anything that i'm not aware of that would increase performance LET ME KNOW! thanks cl fam
i have all the bolt-ons as far as intake, header, y-pipe, and exhaust....felt like when i added the header i lost some bottom end torque but on top end feels waaaay better, not so loud until WOT....as far as chips, i believe they do not work, unless u get the SRT intake with the piggyback for the ECU, and thats about it.....
^^^Exactly.
Chips dont exist for the IS. YOu can get EMU's or SAFC-II to adjust fuel/air.
SRT intake with Piggyback will work. But you can substitute the SRT Piggy for a SAFC-II, as this unit is adjustable. SRT is not.
Upgrades:
Headers(ebay or not), but keep stock Y for low end torque.
Throttle Body
Adjust. cams gears
Cams
But remember, you wont get anything over 215hp, unless your supercharge. Then you will see 350hp. Our cars come stock 185ish Hp
Good luck and happy modding
Upgrades:
Throttle Body
Adjust. cams gears
Cams
woh, we start @ 215
full specs from Motor Trend: http://www.motortrend.com/cars/2001/...ons/index.html
2001 Lexus IS300 Base Sedan Performance & Efficiency Standard Features -
2,999 cc 3 liters 6 in-line engine with 86 mm bore, 86 mm stroke, 10.5 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
Premium unleaded fuel
Fuel economy EPA highway (l/100km): 10.2
Multi-point injection fuel system
Main 66 liter premium unleaded fuel tank
Power: SAE and 160 kW , 215 HP @ 5,800 rpm; 218 ft lb , 296 Nm @ 3,800 rpm
Hypebeast
09-26-11 06:34 PM
