IS300 Aftermarket Parts Upgrade List
I'm new here on CL but have been around the IS scene for several years and a mod on my.is as well (same s/n there). I created a aftermarket parts list which contains all sorts of upgrades from intakes, exhausts and engine internals to all kinds of suspension. This has been on my.is for a while, but I figured I'd post it here to share the wealth of information I have collected into it.
Since I have optimized the size so it loads faster, there may be some incompatibilities with Internet Explorer, I don't have IE around to test it out so I do not know if it affects the useability of the page at all. I would recommend Firefox (v1.5+) which works flawlessly.
The list is updated once again, lots of valvetrain parts plus more brake rotors. In this latest revision, the list has grown from 309 to 477 parts. As usual, let me know if there are any problems/inconsistencies/errors etc.
Anyway, here it is, with 477 parts currently on it:
IS300 BU v3.0 (2/23/2009)
If you have any ideas for things to add or any feedback on what is in there, please post in the thread here, or PM me (either here or my.is) or email me through the link at the bottom of the list.
It gets updated whenever I get a list of things to add, changing it is a lot of work for a single thing, so I prefer to get a bunch of things to update first. It also depends on how lazy I am
It is hard to say how often it will happen in the future because I feel that pretty much everything is on it and there is very little to change. When I first started it, it got updated quite often because it was easy to find more to add.
The list just got a huge update, let me know if there is anything I missed or any errors in there.
Thanks! I have been looking for new rotors and you just helped me find all 4!!!!
Rotora Drilled and Slotted FL R.44083.1C 1 piece drilled and slotted front left rotor, black protective hub coating $139.99
Rotora Drilled and Slotted FR R.44083.2C 1 piece drilled and slotted front right rotor, black protective hub coating $139.99
Rotora Drilled and Slotted RL R.44090.1C 1 piece drilled and slotted rear left rotor, black protective hub coating $121.99
Rotora Drilled and Slotted RR R.44090.2C 1 piece drilled and slotted rear right rotor, black protective hub coating $121.99
dude you effin rock!!
mad props to you
![](http://img.photobucket.com/albums/v312/LowLikeWhoa/Forum%20Funnies/propssdhshda.gif)
mad props to you
