Toyota Airbags on the IS300 wheel?
Are you guys familiar if the 2000-2005 MR2 or Celica airbag will fit the IS300 wheel? I am putting this on my SC and am seeking Toyota badging.
Here is a picture.
![](http://i18.ebayimg.com/01/i/001/23/c1/edad_1.JPG)
Or do you guys know of any other airbag that will fit that is single staged that has Toyota on it?
Here is a picture.
I am willing to bet the harness will be different behind the squib steering wheel unit. If the (typically yellow) harness clips in seamlessly and the bolt pattern matches on sides, you should be fine. Resetting the SRS control module only takes 15 minutes with battery disconnected.
JesLet
IS - 1st Gen (2001-2005)
09-07-07 08:58 PM
