IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Dashboard problem
Old 12-17-08, 07:39 PM
dyt06z
dyt06z's Avatar
Default Dashboard problem
Hi,
I was driving and stopped at a light. Than my dash looked like the pic attached. Can anyone tell me whats going on? Thanks.
Old 12-17-08, 08:25 PM
3rdelement
3rdelement's Avatar
burnt out bulb. search this forum for diy led. several good fixes for your problem
Old 12-18-08, 11:41 AM
Brian231
Brian231's Avatar
These bulbs tend to burn out around 90k. You have to remove the analogue gauge cluster and twist out the bulb which is attached to circular bread board. it is easy to replace and Radio Shack will have these LED's. I changed out my sister's 2005 Camry gauge bulbs at 50k as two burnt out.
Old 12-18-08, 05:47 PM
dyt06z
dyt06z's Avatar
Thanks for the help. I found the dyi on this but was wondering what I should the person at Radioshack about the size of bulbs.
Old 12-19-08, 12:48 PM
Brian231
Brian231's Avatar
That was a good question to ask and I should have stated that in my original post. What I did was remove the cluster and then remove the filament bulbs. Then I purchased LED's with the same sizing and put them in. You can choose amber led's as well. I do not think the cluster on the 1gen has a amber plastic housing, but double check.
Old 12-22-08, 02:48 PM
KPC
KPC's Avatar
i recently did a write up on how to remove and replace the old bulbs with LED's...check it out:
https://www.clublexus.com/forums/is-...tructions.html
Old 12-28-08, 08:25 PM
dyt06z
dyt06z's Avatar
Awesome write up and thanks for the help everyone! I will be changing the bulbs out soon!
Old 02-19-09, 09:16 PM
llllllllll
llllllllll's Avatar
Let me know when you get around to doing this.
I'm local and I want to help and get the experience to do mine too
Old 02-19-09, 09:21 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I'd stick with the bulbs. Plug in LED's are spotty. That's why the DIY in the sticky up top is so much harder to make it look like it should.
Old 03-18-09, 10:04 PM
dyt06z
dyt06z's Avatar
Just an update, I went to Lexus of Wilmington since they said they will do it for 150. They opened the cluster and called me saying that I do not have bulbs on my cluster but LEDS and thus 1100 to fix. I think they are trying to make money. Anyone hear of this before?
Old 03-18-09, 10:07 PM
3rdelement
3rdelement's Avatar
try this. remove the cluster.
on the back you will see the backs of the plastic sockets. remove one of the larger ones and take a picture of it. also if you can take a picture of the entire back of the cluster and post it here. could be as simple as ordering bulbs. not all led installs are hard installed with solder. some are like the diys we mentioned which consist of removing the bulb from the socket and plugging in the led bulb. let us know. and 1100 wow. thats steap.
Old 03-19-09, 12:19 AM
mtn101
mtn101's Avatar
1100 for a couple of bulbs? holy hell, do it yourself.
Old 03-22-09, 09:22 PM
dyt06z
dyt06z's Avatar
Ok, I went around opening the cluster up today...it was a beautiful day here! and i figured out right away that those fools at Lexus didnt even touch the cluster...and the install that was described led me directly to the bulbs...very nice upload there! here are some pics. Now should I just go buy bulbs from Toyota or take a bulb out and go to radio shack or something? Thnks
Old 03-22-09, 09:23 PM
dyt06z
dyt06z's Avatar
here is the bulb after being pulled out
Old 03-22-09, 11:02 PM
3rdelement
3rdelement's Avatar
your very very first step should be to go back to that dealership and demand to speak to the service manager. and ask him to explain the inconsistancy of his story demand some accountability. secondly if you paid anything for the diagnosis, you should have a full refund take place. and finally you should ask him what kind of deal he can make you on the parts.....fyi these bulbs are $2 aprox each from carson toyota. this is really sad.....
but good for you. you can either go the bulb route if you like the red or you can go the actual led route and purchase them from autolumination.com or somewhere like that.
Quick Reply: Dashboard problem
