IS 300 Stereo And PAnel HELP
Ok look i have a 2 problems wonderin if anyone can help
I have a 2005 is 300 stock stereo or whatever i wanna know how to make it play mp3 cds (the cds that you can put over 100 songs on) if possible
Also anyone with subs in their car prob gets annoyed of this the back panel raddles i temp. fixed it but anyone know a way to fix the panel from raddling like how to open it up??
You can't 'make it' play MP3s. If it wasn't made to play MP3s, then it won't play MP3s. Either get a new deck, or an FM transmitted for your ipod or something...
for the mp3 thing: the easiest with great quality is the Vais Unit. just keep an eye on ebay. i got mine for under 100.
for the other part. i know you have to pop the bottom of the back seat up, and then remove it from the car. then the back of the rear seat. then the trim, then the deck will come off. its a pain. what i would do is dynomat the trunk or at least the underside (trunk side) of the rear deck.
good luck
good luck
well i was thinking maybe there was a way like a different stereo i could from the lexus dealer i have to get mine replaced any way the dics changer is totally jammed
well if its just jammed, thats an easy fix. just search here or my.is there are quick instructions on how to remove the radio and take off the panel that gives you access to the problem. i would replace with a nice aftermarket deck before trying to get another factory deck. because with this car you have to replace the amp....and then that means you have to replace the rear speakers. :-\ easier to just get another aftermarket deck. i have an alpine deck i have for sale for $200 if you need one.
i think ima check the dynomating out you know anywhere to get that ? maybe autozone you think or like is it an auto body thing. the mp3 i just am gonna look around on ebay for that and just instal myself i took my entire dash apart to fix a few things under it like some raddlin in it and tried to fix the disc changer but it was to broke to fix
