IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
HELP! Car overheating
Old 01-06-09, 08:45 PM
COOLIS
COOLIS's Avatar
Default HELP! Car overheating
My 2001 Lexus IS300 is overheating and it wont blow any hot air with the heater on. Its also making this funny knocking noise behind the dash. Its done the knocking in the past but got louder since this problem started yesterday. It only makes the noise when I left off the gas. I took the radiator cap off and a piece of it had fallen down into the radiator. I was able to get it out and am hoping that a new radiator cap will fix the problem. I just had the car serviced Friday and stated to the dealer I was heading to the mountains and to check everything. They stated they did. Im not sure if its cause I took the car from warm Orange county up to freezing Mammoth, CA that this problem occurred. Any info would be greatly appreciated.
Old 01-06-09, 08:54 PM
IS3_FTW
IS3_FTW's Avatar
Are you using water or antifreeze. SOunds like you might have an air bubble in your lines. Just flush out the fluid and fill in with new fluid. Just remember to burb the motor
Old 01-06-09, 08:56 PM
FoShoei
FoShoei's Avatar
possible its the thermostat
its not opening at the right degree and might as well replace your waterpump
Old 01-06-09, 09:06 PM
COOLIS
COOLIS's Avatar
I was thinking it could be either of those problems. Could that also be causing the knocking sound? Any other ideas of possible problems. I am suppose to drive 400 miles home tomorrow but doesnt look like thats gonna happen.
Old 01-06-09, 09:26 PM
IS3_FTW
IS3_FTW's Avatar
reset the ECU by unplugging the battery for 15-30 min. then see if the knocking is still there.
Old 01-06-09, 11:03 PM
3rdelement
3rdelement's Avatar
that sound could be the air bubble. ide do a flush and go from there. if you think about it, if there is no fluid circulation due to an air bubble there would be no hot water running in the heater coil ....thus no hot air.
good luck
Old 01-07-09, 12:38 PM
Dr. Yellow
Dr. Yellow's Avatar
what an ironic screen name
Old 01-07-09, 02:47 PM
IS3_FTW
IS3_FTW's Avatar
No hot water = no hot air
LOL
Old 01-08-09, 12:00 AM
COOLIS
COOLIS's Avatar
Turns out it was the thermostat. The car overheated because the radiator cap was broken which cause the thermostat to go.
lionscourt
Performance & Maintenance
10-21-15 08:00 PM
o_man_76
07-04-11 12:08 PM
adamb
16
06-01-05 08:30 PM
kendogger2002
Maintenance
12-10-02 06:38 AM
ChopstiX
08-31-02 10:50 PM
Quick Reply: HELP! Car overheating
