Need some feed back
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
what can i do to my automatic IS 300? Can you swap a 2jzgte into an automatic IS 300 and does the 2jzgte have to be auto that comes with the 6sp? I need some ideas should i keep the stock engine and work on that ?that would most likely be cheaper but the possibilities with a 2jzgte are endless Oh and 1 last quiestion can you stroker kit an auto IS just wondering?
The supra came with a 2jzgte in both six speed manual and four speed automatic forms. I think you can adapt it to your 5 speed e shift as well. Unless you are going for crazy, 600hp plus numbers, most just NA-T the IS300, there are many kits and builders out there.Don't forget, you can build the auto, with torque converters, shift kits etc to handle this power. Full Supra swaps including the six speed manual can be done, but it is very expensive. With the stroker kit, it can work on any 2jzgte auto or manual.
RideZX-6R
Performance & Maintenance
49
11-21-07 06:28 PM
Mortal300
02-14-07 09:39 PM
