How much hp does a short ram intake add?
I was told, if you're looking to add HP to your IS don't waste your time and money with bolt-on's because you will not get any significant power gain. Best bet is to save your money and go turbo.
That's just what I was told and it seems like good advice to me.
Bolt ons and NA mods are not a waste of money ....
You can easily be around 230RWHP with bolt ons and NA mods...
HKS doesnt make a cat back for the IS300! and yes N/A bolt on upgrade do not really yield much horsepower but it will increase it by a bit, it really is down to what you believe is worth it spending all that money for no so big gains its up to you
To above also ecu tune....NO the its a sort of piggy back from SRT and the only reason its needed is due to the intake tubing being 3.5in in diameter .....
I also have a Injen header shield ...... but i run a JoeZ intake kn drop in ...exhaust is Megan header stock y and B pipes and HKS TI-limited axle back.....
N/A mod is cool. it's something different then boost. but you still need to tune it with some kind of piggy back or standalone to make good power out of all the mod you put on. since all the new cars runs with sensors and computer you need to tune it for best result but im sure you still will have lower power then boost if you looking at same amount of money.
