who has megan rear camber kit?
well those are different control arms.
The Camber control arms you already know is for correcting + amd - camber
in simple term how the wheel sits top and bottom
if the top sticks inside the fender and the bottom sticks out that's negative camber that's negative camber
if the top sticks out and the bottom sticks in that's postive camber.
Toe Control arms are another way to adjust alignment
this is how the wheel sits from front to rear.
if the front portion of the wheel sticks inward and the rear portion sticks outward then that's negative toe
if the front portion of the wheel sticks outward and the rear portion is inward then that's positive toe
or vice versa.....when it comes to toe adjustments i always get it backwards =P
yeah i understand that, so to adjust my camber i need RUCA's? i cant find anyone who makes rucas, cept some no name ebay ones, and i have a hard time trusting them. who else makes em??? i need to adjust 4 degrees and get em as close to 0 as possible
megan only makes adjustable toe arms, and apparently, some sites have their information confused saying they are camber adjustment.
